Garage band
This is a discussion on Garage band within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Ow do you install garage band on a 16gig ipad2? I have seen the display models at best buy with it installed..I tried to load ...
Results 1 to 5 of 5
Thread: Garage band
    133876
    Dec 2011
    5
    Garage band
    Ow do you install garage band on a 16gig ipad2? I have seen the display models at best buy with it installed..I tried to load it but it said garage band needs 20 gigs of space then it quit. So what's up here,is there a version for the 16 gig? Little help for a newbie...thanks all
    37823
    479 times
    Cranbrook, Kent, UK
    15,265
    That's strange as according to the App Store it is 501mb.
    Are you trying to download over 3G as there is a 20mb limit so you need to be using wifi to download this app.
    129720
    18 times
    Nov 2011
    474
    Garage Band is 501mb and sounds like you don't have enough memory to install the app.
    133876
    Dec 2011
    5
    Thanks all. I was using my Verizon connection , I will use my wifi connection when I get home and try to download it...
    37823
    479 times
    Cranbrook, Kent, UK
    15,265
    Quote Originally Posted by mediclarry1
    That sounds like the problem......you should be fine once you get a wifi connection.
  1. Garage Band for iPad
    By cflyte in forum iPad Apps
    Last Post: 12-18-2012, 08:41 AM
  2. Garage band settings
    By rmbmt in forum iPad Apps
    Last Post: 08-10-2011, 12:50 PM
  3. Garage Band
    By Gary Powell in forum iPad Apps
    Last Post: 06-30-2011, 09:54 PM
  4. Garage band
    By tecknoes in forum iPad Apps
    Last Post: 06-16-2011, 12:48 AM
  5. Garage Band and Keyboard
    By willywonka in forum iPad Apps
    Last Post: 04-18-2011, 02:02 PM
can not find garage band on ipad2
garageband for ipad install
garageband ipad not installing
garageband loading ipad
how to download garageband for ipad 2
how to install garageband ipad
how to install garageband on ipad
how to install garageband on ipad 2
installing garageband on ipad
ipad 4 memory garageband
ipad garage band not installed
will a 16 gig ipad run garageband
