Tv programmes
This is a discussion on Tv programmes within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi there I bought a tv series off iTunes and played fine for the first episode, but went to watch another episode and the message ...
Results 1 to 2 of 2
Thread: Tv programmes
    133522
    Dec 2011
    Uk
    Tv programmes
    Hi there
    I bought a tv series off iTunes and played fine for the first episode, but went to watch another episode and the message on the screen is (the requested URL is not found on this server)
    Anyone know what's wrong.
    It's not even recognised in my iTunes purchases!
    48665
    481 times
    Brisbane, Australia
    19,265
    Give these steps a try to fix your problem :-
    Do the four finger swipe up to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press one of these apps until they start to jiggle and red minus signs will appear above them all. Press all the minus signs, this will close them, not delete them. It's a good idea to do this regularly just to keep them all running smoothly, I do mine every night. Check and see if it is operating now. if not a restart is in order.
    When your iPad begins to behave strangely these are the first steps you should do to rectify it. Let us know how you go, good luck!!
    iPad 2 64gb 3G
  1. Films and TV programmes have disappeared.
    By johnnopom in forum iPad Help
    Last Post: 10-29-2011, 06:27 AM
  2. iCloud Could Feature Films and TV Programmes
    By Maura in forum Apple iPad News
    Last Post: 05-31-2011, 03:31 PM
  3. BBC iplayer can't stream TV programmes
    By jswa in forum iPad Help
    Last Post: 05-29-2011, 10:59 AM
how to fix the requested url was not found on the server ipad
ipad sayng url is not found?
ipad troubleshoot requested url not found
itunes requested url not found on this server
itunes the requested url was not found on this server
the requested url is not found on this server ipad
the requested url was not found on this server ipad
the requested url was not found on this server itunes
url not found on ipad
url was not found on this server ipad how to fix
videos on ipad say the requested url was not found on this server
why does my ipad say the requested url could not be found on this server
