Bookmark Help Please
This is a discussion on Bookmark Help Please within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Originally Posted by Mickey330 I'm sorry, but I don't know how to fix your problem. I am able to create, move or delete bookmarks easily ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    16699
    Oct 2010
    London
    27
    Quote Originally Posted by Mickey330 View Post
    I'm sorry, but I don't know how to fix your problem. I am able to create, move or delete bookmarks easily within Safari. I don't have the problem you describe (and I'm running on iOS 5.0.1).
    Given that reset or restarting the iPad didn't help, it may be time for a trip to an Apple store and let the Geniuses figure it out. Cause I sure don't know!
    Sorry.
    Please don't apologise Marilyn. It is obviously an unusual problem and I appreciate your contribution!
  3. #12
    48665
    479 times
    Brisbane, Australia
    19,126
    Marilyn, would emptying the multi task bar make any difference. I notice if I do a restart the multi task bar is still loaded. May as well give it a try.
    Do the four finger swipe up to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press one of these apps until they start to jiggle and red minus signs will appear above them all. Press all the minus signs, this will close them, not delete them. It's a good idea to do this regularly just to keep them all running smoothly, I do mine every night. Check and see if it is operating now.
    iPad 2 64gb 3G
  4. #13
    16699
    Oct 2010
    London
    27
    Quote Originally Posted by leelai View Post
    I have tried that several times over the last few weeks and it makes no difference. At this stage I am about to give up on Safari and try an alternative browser.
  5. #14
    48665
    479 times
    Brisbane, Australia
    19,126
    I may be grasping at straws here but I'd like you to try one last thing, whenever you load a web page data is stored on your iPad. Have a look here Settings - Safari - Advanced - Website Data. As you will see it shows every web page you've been to and this can add up to quite a lot of data. Clear this out and see if it makes a difference at all.
    iPad 2 64gb 3G
  6. #15
    16699
    Oct 2010
    London
    27
    As a last resort I have deleted all of my existing bookmarks and their folders. It has resulted in me just having a bookmarks menu and I have two Folders called Bookmarks Bar. I can now add new bookmarks but one of the Bookmark Bar folders will not save any bookmarks. I cannot see how I can delete the non functioning Bookmarks Bar folder. If I can remove this folder I can start all over again by saving my bookmarks.
    Whilst I was deleting all of my bookmarks I noticed that there was extensive duplication of folders and bookmarks.
  7. #16
    48665
    479 times
    Brisbane, Australia
    19,126
    Quote Originally Posted by fixerman
    That is quite unusual that you should have 2 bookmarks bar folders and that there was a duplication of bookmarks unless you had set them more than once, maybe the iPad doesn't recognize bookmarks that have already been saved once. I will look at this myself. Maybe now would be a good time to do a restart and or reset and this may clear the duplicate folder. I would also as a first step clear out the multi task bar. Did you have a look at the Website data that is stored in the iPad at all? I was wondering if it could be a ram issue is all.
    iPad 2 64gb 3G
  8. #17
    16699
    Oct 2010
    London
    27
    Thanks leelai,
    I have cleared both the multitask bar and all of the website data as you suggested. I will now try another reset.
    I have done a reset but I still have two Bookmark Bar folders. Otherwise it's ok as I can now add bookmarks but I would like to get rid of the non functioning Bookmark Bar.
  9. #18
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,267
    Well, it sure sounds as if you've got a "bug" of some sort in your Safari app. Cause you sure can't delete the Bookmarks Bar, it's a stock feature of Safari. And, you can't uninstall/reinstall Safari, because it's a stock Apple app that can't be removed.
    So, if this really, really bugs you, the only solution is to restore your iPad. This entails making a backup of the iPad and then, using iTunes, wiping the iPad and putting a fresh version of iOS 5.0.1 on it. Then, you can put it back the way you had it using your backup. It's not a hard process (I just restored mine yesterday) but it is a bit time-consuming.
    Since it will be a fresh install of Safari, along with the firmware, your new Safari should work fine. It's up to you to decide if this is the way you want to go - because I honestly think that's your only fix, given that you've tried all the suggestions here.
  1. How to delete bookmark ?
    By ritchdude in forum iPad Help
    Last Post: 12-23-2012, 04:56 PM
  2. Bookmark
    By Trevor John in forum iPad Help
    Last Post: 06-13-2011, 06:04 AM
  3. How do I bookmark in 4.2?
    By slothead in forum iPad General Discussions
    Last Post: 01-11-2011, 04:58 PM
  4. bookmark to app
    By jetjock in forum iPad Help
    Last Post: 07-16-2010, 12:52 PM
  5. No bookmark bar
    By ACRViper in forum iPad General Discussions
    Last Post: 06-05-2010, 10:45 AM
all of my bookmarks have disappeared ipad2
cannot add bookmarks on ipad ios 6
cannot add bookmarks on ipad3
duplicate bookmarks and folders ipad
how do i get back bookmarks that disappeared on ipad2
how do you add bookmarks on ipad 2
how to add a new bookmark ipad3
how to move bookmark on ipad2
ipad3 bookmarks
my ipad 2 bookmarks no longer are showing
no history folder in ipad bookmarks
what caused me to lose all of my bookmarks on ipad safari
