iPad2 (soft) Volume slider knob missing
This is a discussion on iPad2 (soft) Volume slider knob missing within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I can not get sound out of my speakers... iPad 2 iOS 5.0.1 Manual (hard) swich set to "Lock direction" Soft swich set to "ON" ...
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By followthesapper
Thread: iPad2 (soft) Volume slider knob missing
    132118
    Dec 2011
    Norway
    iPad 2 iOS 5.0.1
    Speakers are silent, and the knob on the soft volumecontroll slider is not visible.
    Fiddeling whith the hardware soundswich gives no response.
    Have tried rebooting and reinstalling whitout result.
    When plugging in headphones the soft volume slider knob reappears letting me slide volume up and down. Once unplugged the knob vanishes leaving onely the slot.
    Have tried to enter setup and set the manual svich to "Volume on/off"
    Flicking the button gives me the bell showing Volume on/off and level, but still no sound.
    "Hard" volumswich gives no response, and the soft knob is still missing.
    The onely sound I can lure out of the pad is a small "beep" at startup.
    PS I have Norwegian menues on my pad. References to setup choices are translated, and might be inaccurate.
    Anybody got a solution ?
    132027
    Dec 2011
    Sweden
    17
    Did u restore to factory settings
    132118
    Dec 2011
    Norway
    Suppose so. Reinstalled from iTunes bouth system and backup.
    132027
    Dec 2011
    Sweden
    17
    Ok wierd but im gonna google it for you
    55960
    May 2011
    Dallas
    61
    I'm having the same problem. I have a jailbrokren iPad2. I am not sure when or what has happened.
    193958
    26 times
    Apr 2012
    Alba
    399
    Been doing some searching, I can't believe how many people have this problem.
    Found the following four common fixes, the most popular fix was to clean the dock connector.
    1. Just plug your device to a pc, wait for about 10 minutes then your sound will go back to normal.
    2. Try cleaning the bottom 30-pin contacts (dock) with a q-tip and rubbing alcohol
    3. Play a tune on the device and repeatedly plug and unplug the earphones about 10 to 15 times
    4. The new iPad doesn't like having the headphone jack suddenly disconnected while playing an audio source. The solution was to connect headphones, start playing music through the device, and then PAUSE the music. Disconnect the device while the sound is paused, and the problem is corrected. All normal sounds and volume slider returned.
    Hope one of the above solutions helps.
    Strawberry Pearl likes this.
    CLOSING APPS: If an app has stopped responding or closes on launch, try the following: * Home screen * click the Home button twice * Tap and hold on the app * When it jiggles, tap the (-) to close it * Double-click the Home button and re-open the app
    55960
    May 2011
    Dallas
    61
    Quote Originally Posted by followthesapper
    Thanks! I bought a new AC cord and was using my iPad WITH IT ON CHARGE in another room in my house. This particular cord obviously acts like a dock??? Anyhoo, when i unplugged my iPad the slider knob re-appeared. Weird... the cord in my bedroom charges without this happening. I was almost about to reset and restore my iPad.... Whew! :-)
    275529
    Jan 2013
    Quote Originally Posted by followthesapper View Post
    This was extremely helpful for me when I had the same problem with the soft volume slider knob missing. I plugged and unplugged my headphones into the iPad repeatedly, which did not work at first, but then I plugged the iPad into my iMac and plugged/unplugged the headphones and voilą, it worked! Thanks so much for the tips!
  1. Turning down volume on ipad2
    By ohsaa_referee in forum New Member Introductions - Site Assistance
    Last Post: 10-30-2011, 02:46 PM
  2. ipad2 soft leather sleeve?
    By sjleworthy in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-29-2011, 01:09 PM
  3. Replies: 19
    Last Post: 03-14-2011, 10:16 PM
  4. volume up button missing pressure/klick point
    By Spielor in forum iPad Help
    Last Post: 09-07-2010, 12:12 AM
ipad 2 volume control missing
ipad no volume slider
ipad volume control missing
ipad with missing sliding button
lost volume control on ipad
volume button on ipad disappeared
volume control disappeared on ipad
volume control missing ipad
volume control missing on ipad
volume control slider missing on youtube
volume slider missing on ipad
volume slider missing on ipad2
Tags for this Thread
