Contacts keep disappearing-& how to import from main computor?
This is a discussion on Contacts keep disappearing-& how to import from main computor? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; My contacts (addresses) keep wiping out of the contacts book, disappearing. Also how do you import or transfer all of them from main comp. to ...
Results 1 to 7 of 7
    46091
    OMAHA NE
    78
    My contacts (addresses) keep wiping out of the contacts book, disappearing. Also how do you import or transfer all of them from main comp. to ipad2 contacts????? 3 times it has happened !!!!!! Getting p/od !!!!!!
    DICKSTER-----
    46091
    OMAHA NE
    78
    Figured it out---with iTunes open and iPad hooked up select the iPad from the devices on the left column---go to the info tab at top and select "sync contacts" select all contacts or groups. Than hit sync at bottom rh and it should restore all.
    Now we will watch and see if contacts stay.
    DICKSTER-----
    129096
    Nov 2011
    6
    Do you use Plaxo?
    46091
    OMAHA NE
    78
    No I don't and honestly never heard of it. I messed around w/ push and fetch on iPad 2, changed iCloud to fetch and went to main comp, and low and behold the contacts were there when I opened it up. Only the cyber gods know !!!! ?
    DICKSTER-----
    46091
    OMAHA NE
    78
    Thanks for tip about "Plano" downloaded and installed easily-works very good!!!!
    DICKSTER-----
    46091
    OMAHA NE
    78
    CONTACTS STILL DISAPPEAR FROM ICLOUD'S CONTACTS---I can't figure out how to get them into iCloud-I now have them in my apple address book.
    Help please--
    Dickster
    46091
    OMAHA NE
    78
    The problem has something to do with iCloud on ipad2-Push & Fetch-I was now able to get the contacts into my iCloud on macro work station, but I don't know how long they will stay, especially after I start deleting duplicates.
    Dickster-----
  1. How do I import my Gmail contacts
    By Keith66 in forum iPad 2 Forum
    Last Post: 11-20-2011, 05:48 AM
  2. New iPadder- Import contacts via csv file?
    By dlfarley in forum iPad Help
    Last Post: 06-12-2011, 11:53 PM
  3. How can i import contacts from Google
    By diabolical in forum iPad Help
    Last Post: 06-10-2011, 09:56 AM
  4. Import your VZW contacts to the iPad
    By speedlever in forum iPad Help
    Last Post: 01-17-2011, 08:54 AM
  5. Disappearing contacts in IM lite
    By j0yful in forum iPad Help
    Last Post: 06-14-2010, 03:28 AM
contact on ipad 2 keep disappearing
contacts keep disappearing from ipad
contacts keep disappearing on ipad
ipad contacts keep disappearing
iphone 4 contacts keep disappearing
iphone contacts keep disappearing
why do my contacts keep disappearing from my iphone
why do my iphone contacts keep disappearing
