Don't know why, my front camera suddenly hang when I want to take the photo. Anyone can help?
This is a discussion on Front camera having problem within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Don't know why, my front camera suddenly hang when I want to take the photo. Anyone can help?...
do you mean that camera shutter wont open?
