Connecting ipad to TV via USB
This is a discussion on Connecting ipad to TV via USB within the iPad 2 Forum forums, part of the Apple iPad Discussions category; This is probably a daft question, but my TV has a USB port on it, through which I gather I can record programmes to a ...
Results 1 to 3 of 3
    126119
    2 times
    Nov 2011
    89
    This is probably a daft question, but my TV has a USB port on it, through which I gather I can record programmes to a flash drive. But if I connect the ipad, via its USB connection, would it record programmes to the ipad, and if so, where would they be found to view?
    29345
    49 times
    Penarth, Wales, UK
    1,934
    You'd need an app for that, which I'm unaware of, as you can't connect to a tv via USB, only hdmi or Apple tv
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Quote Originally Posted by Waterbabies View Post
    A nice thought, but no, that's not possible.
    Also, the USB port on your TV is one-way (input only), allowing you to attach a USB flash drive so that you can view photos that you've saved on it, that sort of thing. You can't "record" anything that's showing on your TV with it. That would require a DVR like TiVo being connected to your TV antenna or directly to your incoming cable signal.
    Probably not the answer you wanted to hear, but hope it helps!
  1. Connecting from PC to iPad
    By aka_damo in forum iPad 2 Forum
    Last Post: 08-06-2012, 10:31 PM
  2. Connecting an Ipad?
    By catgirl in forum iPad Help
    Last Post: 04-01-2011, 07:20 AM
  3. Connecting an iPad to tv
    By Kwillson in forum iPad Help
    Last Post: 11-07-2010, 01:55 PM
  4. Connecting iPad to TV?
    By Jake872 in forum iPad General Discussions
    Last Post: 09-15-2010, 04:33 PM
  5. Connecting Ipad to car
    By Marcelekusa in forum iPad Help
    Last Post: 07-11-2010, 08:07 PM
connect ipad to tv usb
connect ipad to tv via usb
connect ipad to tv with usb
connecting ipad to tv with usb
how to connect ipad to tv through usb
how to connect ipad to tv usb
how to connect ipad to tv using usb
how to connect ipad to tv via usb
how to connect ipad to tv with usb
how to connect ipad to tv with usb cable
ipad to tv usb
ipad to tv via usb
