Help! Youtube videos won't play
This is a discussion on Help! Youtube videos won't play within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I used to watch youtube videos everyday on my ipad2, it worked well until a few days ago.
I use the youtube apps, the search ...
I use the youtube apps, the search function is fine, and I can see thumbnail of the video fine, but when it started to load after a while it said "movie format not supported", and then the screen went black, i have to return to the home screen.
I tried it repeatedly with the same result, i also try to open it through safari /m.youtube, and encounter the same result, it's as if my ipad2 wont play any kind of video at all.
This really confuse me since a few days ago everything was fine, the "movie format" message does appear but very rarely, and if i try to re-load it would play.
I dont have any problem with cellular network, since i could use the internet just fine.
I try using google, but i can't find any solution to this problem, maybe someone here can help me?
11-29-2011 07:45 PM
Try on your computer. if it doesn't work, then there is a problem with your iPad, the YouTube app, or YouTube itself. Try restarting the ipad. It would help if you gave us the movie name and the account name of the uploader, I could try on my iPad.
Hi, please check this video : caparison dellinger - lead sound, the uploader is 2dellinger. It is just one I randomly selected because all video encounter the same problem.
I can open it through PC and it works just fine. I restart many times , also close other application but still no improvement.
I have just played that clip on YouTube, plays fine on my iPad give these steps a go:
Do the four finger swipe up or double tap your home button to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press one of these apps until they start to jiggle and red minus signs will appear above them all. Press all the minus signs, this will close them, not delete them. It's a good idea to do this regularly just to keep them all running smoothly, I do mine every night. Check and see if it is operating now. if not a restart is in order.
When your iPad begins to behave strangely these are the first steps you should do to rectify it. Let us know how you go, good luck!!
Hi, thanks for the info. I did both, but it still won't work. Perhaps I should visit the apple store and ask someone there.
I can't think of another reason why it would be like this, contacting Apple may just be the answer here.
Maybe someone else will chime in.
I have the same issue that some Youtube clips will play and some will not. I always assumed that it was because of the encoding and that some may be flash based.
The video that was mentioned above does play on my iPad though.
What browser are you using?If you use Atomic and set it to "identify as Internet Explorer X" it would cause this problem. Setting it back to "identify as iPad Safari" will solve it.
My I pad 2 is doing the exact same thing.....my sidekick cell phone did the same thing after the new one came out....it basically forced me to buy the upgraded one...maybe apple is doing the same thing with the iPad two since the three has come out. (description) my iPad worked fine. Gradually I wasn't able to view all videos on YouTube or even shameless to say porn..lol then it just stopped playing vids in general.....my iPad 2 is immaculate and has NEVER been dropped scratched or abused....I'm confused and I want to factory reset it but I want to make sure all of my info gets backed up...if your able to find a solution before 6/24/12 than hopefully I won't have to reset it. Thanks
Banned
This has happened to me before
All you have to do is reboot your iPad, after you turn it back on after rebooting, it's good as new
- You may not post replies
- You may not edit your posts
Forum Rules
By fmmrz5 in forum iPad 2 Forum
Last Post: 03-15-2011, 03:42 PM
By Timmah in forum iPad Hacking
Last Post: 03-08-2011, 02:17 AM
By roszaida in forum New Member Introductions - Site Assistance
Last Post: 08-16-2010, 10:31 PM
By Ultrimate in forum iPad General Discussions
Last Post: 08-01-2010, 10:11 AM
By Yoshiki UK in forum iPad Help
Last Post: 07-20-2010, 06:03 PM
ipad won't load youtube videos
ipad won't play youtube videos
ipad wont play youtube videos
my ipad wont play youtube videos
why cant i play youtube videos on my ipad
why cant i watch youtube videos on my ipad
why wont my ipad play youtube videos
why wont youtube videos play on my ipad
youtube video won't play on ipad
youtube videos won't play on ipad
youtube videos wont play on ipad
youtube wont play on ipad
