need help asap !
This is a discussion on need help asap ! within the iPad 2 Forum forums, part of the Apple iPad Discussions category; this is so annoying ! i have been trying to download a few apps from the app store but when it is about to start ...
Results 1 to 5 of 5
    125681
    Nov 2011
    8
    need help asap !
    this is so annoying ! i have been trying to download a few apps from the app store but when it is about to start on the home screen it suddenly disappears. and also when. i download any app directly on my ipad it also gets simultaneously downloaded on my PC. is there any solution for both the problems ? kindly help
    38632
    Australia
    30
    What has happened they have not installed correctly delete them off your iPad and then go tp app store and check purchase units and re download them .
    This works
    But if there on your screen and look like they are downloading just sync with iTunes and all will be well
    20755
    7 times
    Nov 2010
    Michigan
    436
    Sometimes the app store can act funky, especially if you've got a lot of apps running in the back ground. Close 'em up and re-download from the app store.
    In Settings (on iPad) got to Store, de-select automatic downloads (music, books, and apps are separate), this should keep them from showing up on your other devices.
    125681
    Nov 2011
    8
    hey thnx for ur guidance. it looks like one cannot download apps via 3G directly over the ipad if its over 20 mb. how do u disable this setting ? any idea?
    iPad Wizard
    49745
    370 times
    6,598
    Quote Originally Posted by appy_nyc View Post
    I've read that you can do this by jailbreaking, but can't confirm because I've not JB'd.
    The 20mb cap is set by Apple, in cooperation with carriers.
  1. Help asap re:remote server
    By Ludee00 in forum iPad 2 Forum
    Last Post: 08-10-2011, 08:00 AM
  2. Fill and Signature on form APP advice needed ASAP
    By PhillySportsTC in forum iPad General Discussions
    Last Post: 12-23-2010, 04:04 AM
  3. Replies: 1
    Last Post: 11-02-2010, 08:56 AM
  4. Replies: 6
    Last Post: 06-22-2010, 04:04 PM
  5. Need Help ASAP for Ordering iPad online!
    By bigsubmaween in forum iPad General Discussions
    Last Post: 05-26-2010, 12:52 PM
why there is a 20mb cap on ipad2 when i have 3g
