Ipad 2 - Itouch - USB - Charger - Cables - Compatability
This is a discussion on Ipad 2 - Itouch - USB - Charger - Cables - Compatability within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I am receiving an Ipad 2 as a gift and I have an Itouch. I would like to know if my chargers and current USB ...
Results 1 to 8 of 8
    128425
    Nov 2011
    USA
    8
    I am receiving an Ipad 2 as a gift and I have an Itouch. I would like to know if my chargers and current USB cables for the itouch are compatible with the ipad 2? I did a forum search and learned that the Ipad2 will require more amps to charge than compared with the itouch. So, will the same USB cable that fits the itouch fit the Ipad 2?
    I had an Ipad 2 case question but I used the search feature and found some nice cases. I am a noob and know how frustrating it is for senior forum users to answer easy questions that can be found using the search function...
    Thanks for reading...
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Welcome. Your cables will be OK, but to charge properly at full speed you will need to use the wall charger that comes with the ipad2. Other chargers may charge the iPad but it will be a much slower speed. I often use my iPhone charger to charge my pad at work, but only if I have time to spare!
    iPad Addict
    121
    86 times
    Jan 2010
    Seattle, Washington USA
    1,293
    I'd only add that the 30pin connectors to the iPad and other Apple devices may look very similar but are subtly different. Some older connectors require that you push two little tabs on the sides of the connector to remove it from the Apple device. Otherwise, the connector is "locked" to the iPad. Others have no such little tabs. Both designs work but I nearly returned my iPad to the Apple store when I couldn't remove the 30pin connector (with the little tabs) from my iPad.
    128425
    Nov 2011
    USA
    8
    Thanks for the replies. My USB cables have the (2) push button tabs on the connector to release them. Does the Ipad 2 connector have the push button tabs?
    I would like to have an extra charger at work and leave one at home. Has anybody tried the aftermarket chargers that are on ebay? Or should I get an authorized Ipad 2 charger?
    121312
    Nov 2011
    Not all 3rd party cables will work. I discovered a Belkin iPod cable with a factory tag on it labeled "charge only" will not charge my iPad 2. I hear the tone when I plug it in to the iPad and it immediately states not charging at the top. I am using the supplied wall charger that came with the iPad 2.
    49525
    NJ & FL
    52
    Quote Originally Posted by NYG View Post
    Have bought he cheap Chinese wall plugs and USB to iPad cables from eBay and all have worked flawlessly. Have 2 in the house, 2 in FL house and 1 at the office.
    48665
    481 times
    Brisbane, Australia
    19,239
    Hi and welcome to the Forum!
    iPad 2 64gb 3G
    128425
    Nov 2011
    USA
    8
    I ordered a charger and 6' USB cable from eBay. So far the iPad 2 is awesome!
  1. Question about data cables vs data/charging cables
    By mediaman09 in forum iPad Help
    Last Post: 07-27-2011, 05:19 AM
  2. Using a UK iPad in the US - Compatability
    By Shaun in forum iPad Carriers
    Last Post: 03-12-2011, 01:17 AM
  3. iPad charger verses iPhone charger
    By iPadster in forum iPad General Discussions
    Last Post: 01-05-2011, 02:09 PM
  4. iPad Compatability question
    By chachzilla in forum iPad General Discussions
    Last Post: 10-19-2010, 08:31 AM
  5. Ipad cables
    By trugrip in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-01-2010, 07:07 PM
can i use ipad charger in china
can you use itouch charger with ipad2
can you use usb cords w/ipads
does ipad charger work with ipod
how do i remove charger from my ipad 2
ipad 2 cable labeled charge only
ipad charger cable itouch 4 not compatible
ipad charger works in china
is the ipad ipad 2 connection charging cable work for the itouch?
should i use an aftermarket charger for my ipad?
will a ipad charger charge a itouch
will an ipad charger fit an itouch
