How to fix error 1631 in itunes
This is a discussion on How to fix error 1631 in itunes within the iPad 2 Forum forums, part of the Apple iPad Discussions category; How to fix this in ituner say Ituner could not check for an update to the carrier setting for your iPad. An unknown occurred (1631)...
Results 1 to 3 of 3
    125218
    2 times
    Nov 2011
    Malaysia
    12
    Question How to fix error 1631 in itunes
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Quote Originally Posted by mohdhizami View Post
    Generally the 1631 error is the result of the SIM card slot being loose and/or changing or removing the SIM card.
    This can usually be fixed by toggling cellular data on and off. Settings > Cellular Data > "On/Off".
    If that doesn't work, ensure that your SIM card slot is secured properly then reset your iPad:
    Reset the iPad: You can do this by pressing the Home button and the Sleep/wake switch on the top the iPad's case and holding them down together for at least 10 seconds, until you see the Apple logo. The iPad should then reset itself. The boot up process takes a few minutes and then the iPad should be responsive again. Reconnect it to your computer, open iTunes and click on "Check for update".
    Hope that helps!
    125218
    2 times
    Nov 2011
    Malaysia
    12
    Not work.. I have try copy all file carrier bundles on iphone and copy paste to ipad (/system/library/carrier bundle.. And now the error is gone..
  1. Itunes error 3194 !
    By mnrj94 in forum iPad Hacking
    Last Post: 01-01-2012, 03:07 PM
  2. Itunes store error
    By mosaldin in forum iPad 2 Forum
    Last Post: 10-16-2011, 09:56 AM
  3. Replies: 12
    Last Post: 10-07-2011, 02:40 AM
  4. iTunes Error 7
    By MikeV99 in forum iPad Help
    Last Post: 03-10-2011, 10:31 PM
  5. Error 1631
    By Blackbelt in forum iPad General Discussions
    Last Post: 12-22-2010, 02:54 PM
erro 1631
erro 1631 iphone
error 1631
error 1631 carrier update
error 1631 iphone
error 1631 itunes
iphone error 1631
itune error 1631
itunes 1631
itunes 1631 error
itunes error 1631
itunes error 1631 iphone
