Before the upgrades my iPad 2 printed to our print. But now it won't. The interesting this is it will print from my iPhone 4. What settings do need to check on the iPad ?
Thanks in advance
ThePhotog Jon
Thanks in advance
ThePhotog Jon
Please Support the Wounded Warrior Project
iPod 2nd 8GB, iPod nano 6th 16GB, iPod Classic 7th 160GB, iPhone 4 x 2 16GB, iPad 1 32 GB & iPad2 32GB Blk, 1 iPad 3 32GB Wifi 4G and a iPad 3 64GB Wifi.
What method are you using to print?
The Print n Share app's background printing no longer works in iOS 5. Since they were probably using an undocumented API to make it work, it's unlikely this will be fixed any time soon, if at all.
Other apps may break and need updating to work when you upgrade. Check with the developer.
If you are using an AirPrint printer, then I recommend restarting the printer. Also, if you have not reset the iPad since the update, that often helps with problems right after an update.
