How to close a window?
This is a discussion on How to close a window? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; This is rather a dumb question & for that i apologize. Please teach me how to close an openned window on ipAd2. This is my ...
Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By giradman
  • 1 Post By TheRambler
Thread: How to close a window?
    127772
    Nov 2011
    South koreA
    6
    This is rather a dumb question & for that i apologize. Please teach me how to close an openned window on ipAd2. This is my 1st iPad ever & I have no idea. I was expecting it would be like a laptop where I can just click the x button & the window disappears.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Hello Alo - welcome to the forum!
    Simply tap the 'Home Button' at the bottom middle and the 'open' app should close; also if you are running iOS 5, then multi-finger gesturing can be used, i.e. simply put your open hand on the screen then squeeze your fingers together - the app should close; you can also change apps quickly by using the same finger gesturing horizontally - may take a little practice, but will work (make sure that this feature is 'ON' in your settings app) - good luck!
    Alo likes this.
    127772
    Nov 2011
    South koreA
    6
    Thank you. This is very helpful. More questions coming soon
    A.K
    A.K is offline
    118496
    2 times
    Oct 2011
    India
    90
    It's better to avoid using home button many times IMO .u can use the mullti touch gestures
    1) pinch the screen with 5 fingers. It minimises the app.
    2) if u want to finish or close the app rather than running it in the back ground the gesture is swiping up with 5 fingers from the bottom of screen.the tray of running apps is shown and u can close the required apps by holding one of them till they start to wiggle and then closing it.
    3) u can interchange the apps or multitask by swiping horizontally using 5 finger swipes.
    4) double pressing the home button also shows the tray of running apps.
    I hope this helps
    from my white I pad 3G/wifi 16 gb
    67820
    109 times
    Jun 2011
    Lancashire, England.
    3,043
    Hi allo, as has been said, the middle (home) button is the equivalent of the windows 'x' button, for a more permanent close at the end of use, which also helps battery life, double click the home button quickly, then when the icons show press an icon and hold till they wiggle, a red 'x' is displayed, press it on each icon and this will close them in the iPads memory, it helps to speed up the iPads processing too.
    Remember to save any unsaved info in the programs before you permanently close them.......don't want to lose valuable info!
    A.K likes this.
    64GB wifi ipad2 iOS 6.1.2 (Jailbroken using Evasi0n) : 120GB iPod Classic (Filled with Rock Classics!) : AppleTV 2G iOS 5.0.2 (Jailbroken using seas0npass) : iPhone 3GS 16gb iOS 6.1.2 (Jailbroken using Evasi0n) : iPhone 3GS 32gb iOS 6.1.2 (My Rambling Tool is now Jailbroken using Evasi0n) : iPhone 4 16GB iOS 6.1.2 (Jailbroken using Evasi0n) : iPhone 4S 64GB iOS 6.1.3 (Stock, so I can stream Sky Go)
    127772
    Nov 2011
    South koreA
    6
    thanks everyone!
  1. Scroll in a window
    By dfrench62 in forum iPad 2 Forum
    Last Post: 11-09-2011, 10:52 AM
  2. Window Seat Geek!
    By Nonie3234 in forum iPad General Discussions
    Last Post: 02-01-2011, 12:15 PM
  3. New Window Popup
    By sm2004 in forum iPad Help
    Last Post: 12-27-2010, 07:19 PM
  4. Can I add a app icon to window that...
    By rbest in forum iPad General Discussions
    Last Post: 11-30-2010, 10:56 AM
  5. Replies: 0
    Last Post: 06-09-2010, 01:18 PM
close windows on ipad
closing windows on ipad
how do i close a window on my ipad
how do i close windows on my ipad
how do you close windows on ipad
how to close a page on ipad
how to close a window on ipad
how to close ipad windows
how to close window on ipad
how to close window on ipad 2
how to close windows in ipad
how to close windows on ipad
