iPad battery performance
This is a discussion on iPad battery performance within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello, can you help? I've updated all my apps on my iPad and am now experiencing woeful battery life. I'm loosing at least 11-14% battery ...
Results 1 to 10 of 11
Like Tree5Likes
Thread: iPad battery performance
    116022
    Oct 2011
    10
    Hello, can you help? I've updated all my apps on my iPad and am now experiencing woeful battery life. I'm loosing at least 11-14% battery every hour is anyone experiencing this and does anyone have any suggestions? I'm running os4.3.5.
    118950
    Oct 2011
    13
    Have you tried closing down the apps in the background..... Double click your button and all the background apps will appear... Press x and stop them from running... May be the problem.
    joukowski likes this.
    iPad Addict
    121
    87 times
    Jan 2010
    Seattle, Washington USA
    1,293
    I doubt that it is apps running in the background. They don't really "run." Unless you have some reason to remain on 4.3.5, I'd strongly advise you to update to the most recent version of the OS (5.0.1). That may not solve your problem but it will eliminate one important variable.
    116022
    Oct 2011
    10
    yeah i'm 1/2 thinking it could be one of the updated apps in the background that's draining the battery. I've just now deleted all apps I don't think i need and just waiting for a 100% charged so I can totally close all apps and put the iPad to sleep & see what happens tomorrow morning....
    jsh1120, i was really keen to get OS5 onto the iPad but after hearing a lot of bad press from people at work over what the latest OS release is doing to their iphones is a bit worrying for me although i don't have an iphone... I also hear apple is working on a newer OS5 that is meant to fix all these bugs, is there any merit in this news? Should I wait for this new release?
    All ideas welcome!
    52510
    142 times
    May 2011
    Good ol' Midwest
    2,320
    Quote Originally Posted by joukowski
    All ideas welcome!
    iOS 5.0.1 helped a lot with things 5.0 messed up.
    Sent from my White iPad 4.
    iPad Addict
    121
    87 times
    Jan 2010
    1,293
    Quote Originally Posted by joukowski View Post
    All ideas welcome!
    A couple of points. Although a "rogue app" could be draining your battery, the software architecture of iOS combined with the requirements Apple imposes on apps delivered through iTunes effectively eliminates the problem. Unless you have a corrupted app (and even then) I doubt that apps are the source of your problem. This isn't the place for a discussion of how "multi-tasking" works in iOS, but if you're not running an app in the foreground it is almost certainly "suspended." There are a few exception to this rule, but they wouldn't account for your problem. A much more likely villain is screen brightness set to maximum and not sleeping or wifi or 3G searching.
    Second, the update to iOS 5.0 is already available. It's the version you'll get from iTunes (5.0.1) and it resolves (supposedly) the battery drain issues on 5.0. (Though it was never clear if the problems afflicted the iPad. Most complaints were about the iPhone.)
    If you find you're still experiencing problems with excessive battery drain, you may have a faulty battery. However, you should recognize that a battery drain of about 11% per hour is not unusual (unless the iPad is sleeping.) At that rate of drain, the iPad would last about 10 hours and that's what is to be expected.
    116022
    Oct 2011
    10
    Oops I left out an important detail in my first post: the batt drain occurs whilst the iPad is asleep... Which is also what I should be doing right now - lol. Good night everyone!
    127027
    Nov 2011
    UK
    I did experience the battery running down ridiculously quickly on my iPad2 after updating to the first iOS 5, but it only happened once, and since updating to the latest iOS 5 it hasn't done it again.
    One thing that I find has a great influence on battery life when my ipad is in my bag is how full my bag is. I have an otterbox defender case and the rubber bit over the top of the home button sits proud and can get pressed causing the unlock screen to come on, took me a couple of days to work out what was going on...simple solution; carry less crap in my bag
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    Battery drain like that is a pretty good indication that a process is panicking in the background. It's not unusual for this to happen after a bad upgrade, but it's quite unusual to be consistent on a well established installation.
    If you are fully rebooting the iPad (turning it full off and back on again) and the drain still persists then I would suggest a full restore, but that is quite a drastic course of action so make sure you prepare (sync and backup). You will be forced to go to 5.0.1, but should still be able to restore your files, settings, etc. from the backup.
    IF on the off-chance the battery drain persists after that, the problem is likely something in your backup, so you may need to restore again and set up the iPad as a new device. The downside of that is you will lose your settings and app data, although you can of course get all your apps, media, etc. re-installed via iTunes.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    119443
    Nov 2011
    canada
    9
    I have a first gen iPad. I've noticed that my iPad battery drains pretty quick as well, even over night when not in use. I never power the iPad completely off, I just put it into sleep mode and it would still lose power over night. One thing I've started doing is putting the iPad into "airplane" mode over night. That way it doesn't continuously search for wifi signals, and bluetooth is deactived. The next morning I have the same battery strength as I did the night before. Doesn't really explain why the battery drains so fast in the day however. I know it's almost 2 years old next April, but it seems to be dropping faster since the iOS 5 update, and even the 5.0.1 hasn't helped. I use my iPad A LOT so perhaps it's just standard procedure for a battery of this age and use.
  1. Battery Drain / Performance in IOS5 Update
    By Twiddles in forum iPad OS
    Last Post: 11-09-2011, 02:49 PM
  2. 4G/LTE Verizon Performance for a Wifi Only iPad 2
    By jsh1120 in forum iPad Carriers
    Last Post: 10-12-2011, 08:11 PM
  3. Goodreader performance on iPad 2?
    By southdrexel in forum iPad 2 Forum
    Last Post: 04-17-2011, 10:50 PM
  4. Magician uses iPad for performance
    By kheldour in forum iPad General Discussions
    Last Post: 06-02-2010, 09:33 AM
ipad battery draining too fast
ipad battery drains too fast
ipad loses power quickly
ipad losing power fast
ipad losing power quickly
why does my ipad battery drain so fast
why is my ipad 2 battery draining so fast
why is my ipad losing battery so fast
