Question about battery charging
This is a discussion on Question about battery charging within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi. I was wandering if anyone knows whether leaving an iPad plugged in after the charge has finished has any negative effect on battery performance? ...
Results 1 to 4 of 4
    103991
    Sep 2011
    22
    Hi. I was wandering if anyone knows whether leaving an iPad plugged in after the charge has finished has any negative effect on battery performance? For example if I plug it in tonight when I go to sleep and leave it plugged in for 8 hours even though a full cycle charge only takes 3 hours or so, will this effect the battery performance?? Cheers.
    13576
    751 times
    Aug 2010
    Western NY state (USA)
    9,313
    Not as far as I am aware. The battery/iPad are set up to stop charging once full.
    I've been plugging my iPad in every night for the past year and have noticed zero negative effects. So, there's that.
    It's a built-in feature - the iPad battery won't overcharge.
    103991
    Sep 2011
    22
    That's good to know. Cheers. I thought it would be ok. 99% of people will charge overnight.
    iPad Addict
    121
    86 times
    Jan 2010
    Seattle, Washington USA
    1,293
    No problem at all. Assuming you are using either the Apple equipment or its equivalent the battery will not "overcharge."
  1. Battery charging question
    By cvadh387 in forum iPad General Discussions
    Last Post: 04-27-2011, 02:03 AM
  2. iPad battery question when charging
    By J.D in forum iPad Help
    Last Post: 01-14-2011, 01:58 AM
  3. Charging a New Battery
    By Solaris in forum iPad General Discussions
    Last Post: 11-03-2010, 09:20 AM
  4. charging the battery
    By Mexicat in forum iPad General Discussions
    Last Post: 07-14-2010, 03:31 AM
  5. Battery charging
    By Seadog in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-05-2010, 09:29 PM
battery charging
does ipad stop charging
does ipad stop charging when battery is full
ipad battery charging
ipad mini battery stops at 99%
ipad mini charging to only 99%
is it safe to leave ipad on charge
leaving ipad plugged in
leaving ipad plugged in after charging
my ipad mini battery is at 99%
ok to leave ipad plugged in after charging battery?
will ipad 2 stop charging when battery is full?
