icloud question
This is a discussion on icloud question within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I Am trying to set up icloud on my ipad2, but, when I go into settings, I am not seeing icloud on the left side ...
Results 1 to 10 of 10
Thread: icloud question
    124372
    Nov 2011
    11
    icloud question
    I Am trying to set up icloud on my ipad2, but, when I go into settings, I am not seeing icloud on the left side list. Am I missing something?
    53991
    2 times
    May 2011
    Maryland
    180
    Is your version if iTunes updated to version 10.5.1? It needs to be.
    124372
    Nov 2011
    11
    It says 10.5.1.42
    124372
    Nov 2011
    11
    Not sure what I did but it looks like it is all working now!! Thanks for your help!
    124372
    Nov 2011
    11
    Ok I lied....all my stuff sync'd but I still don't see the cloud under my settings....
    1523 times
    Walla Walla, WA
    15,431
    Have you updated your iPad to iOS 5? iCloud only works with iOS 5 and later.
    If you are not sure, you can check your iOS version by going to Settings > General > About.
    124372
    Nov 2011
    11
    My version is 4.3.5. So, how do I update?
    1523 times
    Walla Walla, WA
    15,431
    You need to make sure you are running the latest version of iTunes on your computer. You hook up your iPad, and if it does not prompt you select the iPad, got to the Summary page, and click on Update. I recommend the download only options. It has fewer problems, in general.
    Once the download is finished you connect the iPad again to do the actual update.
    I highly recommend reading over this thread before you start. You may have no problems at all, probably won't, but it does not hurt to be prepared.
    iOS 5 and 5.0.1 Upgrade Troubleshooting
    Also, the update has several stages with reboots and pauses in between. Do not disconnect the iPad until the very last sync with iTunes.
    Also, also. If you have important files on the iPad, make backups of them. This full update will erase all content from the iPad, and while it should restore the apps and data later it has been known to fail.
    Also, this video about preparing for the update isn't a bad place to start.
    124372
    Nov 2011
    11
    Thanks for all the information! I updated and now I am good to go!
    1523 times
    Walla Walla, WA
    15,431
    You're welcome. Glad it worked.
  1. Newbie - question on iCloud?
    By megvic in forum iCloud
    Last Post: 11-14-2011, 01:09 PM
  2. Icloud question
    By Larryfgraver in forum iPad OS
    Last Post: 10-23-2011, 09:04 AM
  3. iCloud and Calendar question.
    By Blokken in forum iCloud
    Last Post: 10-18-2011, 10:25 PM
  4. iCloud question
    By sjleworthy in forum iPad 2 Forum
    Last Post: 10-14-2011, 10:56 AM
  5. ICloud question
    By Ed62 in forum iPad OS
    Last Post: 10-13-2011, 01:33 PM
cloud not showing in settings
icloud is not in my settings
icloud not in my settings
icloud not in settings
icloud not under settings
ipad no icloud settings
no icloud in my settings
no icloud in settings
