Results 1 to 9 of 9
    71902
    Jun 2011
    Southern California
    22
    Fast Way to Run Battery Down to Zero
    Have a new iPad 2 and would like to run battery down to zero and then recharge. Is there a fast way to get it down
    To zero? Also can I just leave it on overnight (keep screen on)?
    2 iPad2s 32gb & 64gb AT&T, 1 iPad3, 32gb Verizon
    52510
    70 times
    May 2011
    Good ol' Midwest
    1,911
    You don't need to run the battery down and yes you can leave it on all night.
    Sent from my White iPad 4.
    71902
    Jun 2011
    Southern California
    22
    Quote Originally Posted by MoonlitSonata View Post
    Thanks for the info....I was running it down because Apple said to do that once a month at this link:Apple - Batteries - iPad
    iPad Addict
    39793
    7 times
    Oxford, MS
    1,044
    Quote Originally Posted by bww
    You don't have to do that. With normal use and normal environment your battery will withstand. I had an iPhone 3g refurb for 25 months. No charge problems and I would estimate battery was still 85% strong. Was doing much better than this i4
    I have iPad 2. Received 4/18. Lowest I ever let it get was 10 becuz ppl were playing games and crap. With my normal use on a heavy day I get down to 50ish. Power up at bed time (put Padi on her pillow) and I pull cord on a turn over. No battery qualms. Can watch about 4 movies on Netflix wifi and still have 30%. I really believe apple engineers stand behind their batteries.
    [COLOR="] If you don't know me by now, I will never ever ever leave Apple. [/COLOR]
    iPad Wizard
    49745
    381 times
    6,675
    Apple suggests you run down your battery once a month so you can recalibrate the battery indicator. If you choose to do that by purposely running it down, rather than letting it run down through regular use, you can jack up your brightness and stream video, for instance.
    I don't see a need to do that, but if you want to, that's one approach.
    62572
    Jun 2011
    Philippines
    93
    Since your iPad 2 is new, you do not need to do a calibration just yet. I bought mine last June and I can only think of a couple of instances that I managed to drain the battery. Usually I use it for two days (for work and personal use) and by the time it reaches 10%, I am already at home and will be charging it next to my bed while still using it. The iPad has a really good battery.
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    This ^^
    Although Apple suggest a drain once a month I never remember!
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
    iPad Addict
    121
    87 times
    Jan 2010
    Seattle, Washington USA
    1,293
    Quote Originally Posted by Kaykaykay View Post
    This is a frequent source of confusion. Lithium Ion batteries do not need to be completely drained to function properly. In fact there is a protection built-in to prevent completely draining the battery since it's not good for LI batteries. Nor does the battery have to be fully charged before using the first time. That was true of an earlier generation of batteries with different storage technology. KayKayKay has noted the crucial point that is often missed. Apple suggests draining the battery once a month NOT for the sake of the battery, but to provide up-to-date information about the speed of charge/discharge for the battery MONITOR...that little X% indicator on your iPad screen. In order to function properly that indicator needs to know the current state of the battery AND an estimate of the time it requires to charge/discharge fully. Since the latter information changes over the lifespan of a battery, they suggest you keep it updated.
    71902
    Jun 2011
    Southern California
    22
    Thank you all for such good comments. I think I have got it now. The info from Apple really only has to do with calibration not battery life. I have had this iPad for about 3 weeks and the battery life has been incredible, it just seems to last forever no matter what I am doing. I will go back to what I was doing before I ran it all the way down which was using it and charging when the battery got down to around 50% depending on what I was using the iPad for the next day.
  1. Battery draining fast...
    By MoonlitSonata in forum iPad 2 Forum
    Last Post: 06-09-2011, 01:13 AM
  2. Battery runs out of juice very fast
    By thrawn60 in forum International iPad Users
    Last Post: 05-07-2011, 09:42 PM
  3. Why does mt battery go down so fast
    By Mrsmiley2008 in forum iPad Help
    Last Post: 03-14-2011, 09:18 PM
  4. How fast is Apple's "Fast, Free, Shipping"?
    By jrp95 in forum iPad 2 Forum
    Last Post: 03-11-2011, 12:13 PM
  5. how fast is your 3g
    By alwayslearning in forum iPad General Discussions
    Last Post: 05-02-2010, 07:57 PM
fastest was to run down battery in two hours iphone
fastest way to drain ipad battery
fastest way to run down ipad battery
how to purposely run down a battery on iphone
how to run a battery down
how to run down battery on ipad
how to run down ipad battery
how to run ipad battery down
how to run the battery down really fast
running down a battery
what can run your battery down the fastest
what runs a battery down
