ghost finger takes over my Ipad!
This is a discussion on ghost finger takes over my Ipad! within the iPad 2 Forum forums, part of the Apple iPad Discussions category; my Ipad 2 started having random "taps" like a "ghost finger" it does it all opens safari starts typing, changes settings, srinks and expands pages, ...
Results 1 to 10 of 14
    124531
    Nov 2011
    ohio
    my Ipad 2 started having random "taps" like a "ghost finger" it does it all opens safari starts typing, changes settings, srinks and expands pages, you name it, it does it. I did find that when it opens a key pad I can type a "N" by passing my finger over the letter. it does not do it all the time. turning it off and on repeatedly will sometimes fix for awhile. I have removed all the apps., updated the os, reset the settings. at this point it seems like a hardware rather than software. any thoughts
    102113
    Sep 2011
    80
    i dont have a useful suggestion, but it sounds possesed to me. maybe you need an exorsist?
    584 times
    Dayton, WA
    13,198
    If you haven't, you should try a reset.
    After that you are left with a restore, and if that does not fix it then you are right, it is probably hardware. Hopefully you are still under warrantee.
    124780
    Nov 2011
    Chicago, IL
    5
    Make sure your screen is super-clean. I believe there are proximity sensors in addition to the magnets used by the smart cover that "wake up" the screen for touch input and can also glitch if left on..
    124531
    Nov 2011
    ohio
    update
    sorry forgot to thank everone and update you. In case someone else has this problem. tried all your suggestions, no go, Is under warranty, back to the store I went.
    Drove a little over an hour to store.(Closest that had one at the time.) the retailer was limited help, " We don't have a way to repair and you are passed our store policy for return/exchange time". The "Geck" (thats what they are called!) did direct me to "closest" apple store with a " genius bar", an additional 45 minutes! Now two hours from home, I had to make an appointment to talk to "a Genius", two hour wait. cruised the mall. finally got to see somone. Service was great! He had never seen an ipad do this before. Said it must be hardware, got me a new one, help to move my "stuff", reload and reset everything. Was on my way. From what I was told and over heard next to me it seems If you ever need repair out of warranty, it starts at 345 dollars no matter what apple product you have. Maybe others have found diff. but that was the price that day. My warranty did not start over either, I have 100 odd days left. Does that seem fair? maybe the industry standard. When I said something, It was suggested that I add the extended warranty. Sorry to bore you but maybe for anyone that needs repair someday my exp. will help.
    48077
    10 times
    Illinois
    488
    Quote Originally Posted by Thom14940 View Post
    Updates are always good. Thanks
    18528
    Oct 2010
    Bumpass, VA
    43
    From my general consumer experience, the fact that your 'replaced' iPad wil *retain* your remaining 100 days of warranty coverage from the initial purchase seems more than fair to me. Replacement of other electronics have, in my experience, *been* the coverage of the original warranty...and while you walk away with a new replacement, that new replacement has zero warranty (unless an extended one is purchased). Good for you!
    iPad Wizard
    49745
    370 times
    6,602
    Quote Originally Posted by w1ngman View Post
    Yes, seems perfectly reasonable to me, too.
    Banned
    152912
    Jan 2012
    Toronto
    33
    in iTunes, after you restore the system, do not restore any backups, set it as a new device.
    114949
    Oct 2011
    The Great Northwoods of Wisconsin
    20
    I remember something thing like that happening to my work computer when the IT guys needed to fix a problem on my computer and they were working from a different part of the building. It was real spooky.
    Jim
  1. Ghost Armor
    By Lenc in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-06-2011, 12:22 PM
  2. Apple Takes Pity on Husband Denied iPad 2 By His Wife!
    By Maura in forum Apple iPad News
    Last Post: 04-01-2011, 08:49 AM
  3. Replies: 47
    Last Post: 10-01-2010, 12:14 PM
  4. Two Possible iPad Rivals Give Up the Ghost
    By iDan in forum Apple iPad News
    Last Post: 05-03-2010, 09:00 AM
  5. Pee-wee Even Takes Cracks at the iPad!
    By iDoug in forum iPad General Discussions
    Last Post: 01-30-2010, 02:14 PM
ghost in my ipad
ghost typing on ipad
ipad 2 ghost touching
ipad 2 ghost typing
ipad 2 ghosting
ipad 2 hard reset fixes ghost typing
ipad 2 random taps
ipad ghost typing
ipad random typing
ipad screen random input
iphone 4 ghost typing
iphone 5 ghost finger
