Results 1 to 8 of 8
    122845
    Nov 2011
    pc not recognizing ipad 2
    every time i connect ipad 2 to pc .pc and itunes not recognizing ipad 2
    but ipad 2 when connected to pc become a charging mode.i don't what i have to do.i also connect ipad2 to another pc but still not recognizing.i thank it maybe usb cable but it charging and that mean it work.
    please help
    121898
    2 times
    Nov 2011
    Monterrey, Mx
    57
    Well, you must to review the time on your iPad, date, time... Also in the computer. Reset your iPad, and restart your computer. Maybe you must to do it another thing, in that case if you search in the internet about troubles with date and time you will find the rest of the steps.
    VG (fallaces sunt rerum species)
    iPad Ninja
    49414
    88 times
    North Carolina
    1,963
    Hello Weal - welcome to the forum! You might need to clarify your problems more clearly, please - just a few questions to answer:
    Are you using the same computer that you setup & registered your iPad to in the first place?
    Second, plugging your iPad into another computer will require that you register to that machine also if the two are to be used together.
    Third, an iPad connected to an underpowered USB port on a computer will indicate 'not charging' - use the charger that came w/ your iPad - this has been discussed in many previous threads - searching will help.
    Please respond to these questions and hopefully your problems can be sorted out - good luck!
    142027
    Dec 2011
    Hi!! I am really getting the hang of this iPad 2 but I have one problem.. It charges fine w/ wall charger and when connected to PC (not Mac) I can connect fine to iTunes. I arranged all my apps easily into folders that way. BUT iPad won't charge thru that connection. I have a few different apple cords so I have tried them and still it says "not charging". I see mentioned here that could mean my USB port is underpowered.. Can someone tell me what that means and if there is a way to fix it? I run win7 on a computer that is approx a year old. Help!!!!
    Thanks!! /Nancy
    37823
    538 times
    Cranbrook, Kent, UK
    15,671
    Quote Originally Posted by iknowyouare
    Thanks!! /Nancy
    Even though it says it isn't charging it actually is, albeit very slowly, due to getting less power through a USB port it only trickle charges.
    142027
    Dec 2011
    Quote Originally Posted by Gabriel1
    Thanks!! Good to know!! I think it's a shame that I can't multi-task and charge the iPad while playing on iTunes but I can definitely deal w it! Mostly it will be wall charged anyhow. What is the deal with car-charging? Does that go ok? We love to camp in our vintage trailer and being able to connect w the net thru free wifi is always a plus..but sometimes that means having to charge toys in the car.
    Ok, back to wurdle..lol
    /Nancy
    142027
    Dec 2011
    Ok still learning .. I realize that the iPad charger is stronger than the iPhone one.. Would it be harmful to charge my iPhone with the iPad charger? I realize my iPad will trickle charge thru my underpowered computer USB port. I am just trying to configure my charging sitch for the most convenient optimum use and still have wall plugs left for my husband and his droid.. LOL
    /Nancy
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    Quote Originally Posted by iknowyouare View Post
    /Nancy
    It will not be harmful, just slower...
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
  1. itunes not recognizing iPad
    By neilweaver in forum iPad Help
    Last Post: 10-17-2011, 02:42 PM
  2. iTunes not recognizing Ipad
    By a.arkwright07 in forum iPad Help
    Last Post: 06-13-2011, 08:17 PM
  3. iTunes upgrade not recognizing iPad
    By michali in forum iPad Help
    Last Post: 04-23-2011, 11:26 PM
  4. Computer not recognizing iPad
    By Jackiemad in forum iPad Help
    Last Post: 01-31-2011, 07:05 AM
  5. Laptop not recognizing ipad
    By naaaaance in forum iPad Help
    Last Post: 11-24-2010, 03:16 PM
computer not reading ipad
computer not reading ipad 2
computer not recognising ipad
computer not recognizing ipad
computer not recognizing ipad 2
computer not recognizing ipad when connected
computer not seeing ipad
laptop not recognizing ipad
pc does not recognize ipad
pc not recognizing ipad 4
