3G
This is a discussion on 3G within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have 3G service, Bell mobility. Every time I try to use it I cannot get a line. The bell 3G shows at top left ...
Results 1 to 4 of 4
Thread: 3G
    118265
    Oct 2011
    9
    3G
    Every time I try to use it I cannot get a line. The bell 3G shows at top left with plenty go strength but whenever I open safari I get the message that the connection is dropped. Mail has similar issues.
    According to Bell this is a device issue as it happens everywhere. So they're useless.
    Any ideas?
    John
    116 times
    15,249
    It might be worth trying a reboot. Turn the iPad off and then press and hold the Power and Home buttons for about 10 seconds until the white Apple logo appears. The iPad will reboot - no apps or user data are lost.
    See if this fixes the problem.
    118265
    Oct 2011
    9
    Thanks Tim. tried it with no luck. off to the Apple Store tomorrow
    John
    116 times
    15,249
    One last thought - check that you have cellular data enabled in the 'Settings' app.
