Results 1 to 5 of 5
    103001
    Sep 2011
    Ohio
    Bluetooth question
    Hi. Just got an iPad 2 and it's totally new to me. I also got a Bluetooth keyboard to go with it. Should i leave the
    Bluetooth turned on all the time on the iPad or will it drain the battery? I have been turning it off but it's a pain to have to go into settings all the time to turn it off and on so is there a widget (yes, I come from android) or icon or something I can put on my home screen to simplify turning off and on? Thanks.
    55325
    May 2011
    Austria
    169
    Yeh, I've heard a lot of people wishing for this functionality. Is your iPad jailbroken? If so maybe something like sbsettings would make life easier :-)
    iPad Addict
    121
    87 times
    Jan 2010
    Seattle, Washington USA
    1,293
    My guess is that his/her iPad isn't jailbroken given that it's "new." To answer the question, No. Widgets are evil in the Apple world. A very few are allowed (e.g. calendar) but most are prohibited. This approach avoids situations (common in Android where I, too, come from) where numerous widgets can lead to lags on devices without enough processor power and RAM to support them along with the apps you want to run. Since Apple wants to use a relatively limited power chip and relatively little memory (512K on the iPad 2), they have to constrain the multi-tasking capabilities of the iPad to prevent unpredictable lags and slow downs. (Those are VERY BIG NO NO's in the Apple world.)
    As far as bluetooth is concerned, yes, it will drain your battery. Significantly. If you're using a bluetooth keyboard turn it off when you're not using it to save its battery (though most bluetooth keyboards go to sleep on their own when not in use) and turn off the bluetooth connection on the iPad to save its battery.
    iPad Ninja
    49414
    88 times
    North Carolina
    1,964
    Quote Originally Posted by 2dapi View Post
    Hello and welcome to the forum!
    You're over blowing this situation - first, the power consumption on your iPad for Bluetooth (BT) is low, so if you are recharging on a regular basis, really does not make much sense to worry about it.
    Second, the Apple BT keyboard (KB) has an intelligent power regulation program, i.e. the KB turns itself off after a period of non-use and then reactivates when needed - check HERE for further information.
    Now the issue may be 'how often' you use your BT KB? If used infrequently I would likely 'turn off' the iPad selection and also possibly remove the batteries from the KB; but if used frequently, I see no problem in leaving BT on in the iPad and letting the KB regulate itself (suggestion - carry a couple of extra batteries w/ you - I've had to replace them once on my KB) - good luck and please post back if these comments do not answer your question(s) -
    103001
    Sep 2011
    Ohio
    Thanks for replies. It is not jailbroken. It is new and i have never done anything like that and dont trust myself quite yet. Actually the keyboard itself does not take batteries. Its USB charged. I was just wondering if there was an easier and quicker way to turn bluetooth on and off on the ipad. The keyboard has an on/off switch that is convient. Like I said, I come from Android have gotten used to
    the "widgets" and didnt know if I was missing something. I have gotten my answer though so thanks everyone Thank
    you.
  1. Bluetooth Keyboard Question
    By wbrocks in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-04-2011, 04:32 AM
  2. Airplay And Bluetooth Question
    By Munky in forum iPad Hacking
    Last Post: 03-08-2011, 06:04 PM
  3. Bluetooth Headset/Remote Question
    By Munky in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 01-18-2011, 09:48 PM
  4. Question about development of bluetooth app.
    By strad in forum iPad Development
    Last Post: 10-05-2010, 04:58 AM
  5. Freedom Universal Bluetooth Keyboard, question?
    By Ultrimate in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-19-2010, 10:29 PM
bluetooth drain ipad battery
can leaving bluetooth on ipad on kill battery
does bluetooth drain ipad battery
does leaving bluetooth on drain battery
does leaving bluetooth on drain battery ipad
does leaving bluetooth on drain iphone battery
does the bluetooth keyboard drain ipad batteries
easy way to turn on bluetooth ipad
ipad leaving bluetooth on
ipad leaving bluetooth on leech battery
should i leave bluetooth on my mini ipad
turn on bluetooth
