confused about charging
This is a discussion on confused about charging within the iPad 2 Forum forums, part of the Apple iPad Discussions category; when I first got my iPad2 I was using it daily and letting the battery completely run out before charging. Then I read that this ...
Results 1 to 4 of 4
    105749
    Oct 2011
    Kent UK
    14
    when I first got my iPad2 I was using it daily and letting the battery completely run out before charging. Then I read that this is called deep discharging and shortens the battery life. so if Im not to let the battery completely run out before charging then when should I charge it , 60% 40% 20%. Can somebody please advise on this.
    113246
    Oct 2011
    Massachusetts
    47
    I let mine get down to 50% then charge it. I know on my cell phone the battery would not keep a charge long when I was constantly charging the battery. When I got the replacement battery I would not charge it until I got the low battery indication from the phone. I don't know if this holds true for the Ipad2 or n ot. Hopefully those with more experience will jump in.
    IPAD 2 Black 16 G WiFi + 3G
    iPad Ninja
    49414
    80 times
    North Carolina
    1,924
    Hi Daved2006 - welcome to the forum!
    Now, there are numerous threads & posts on the iPad's battery, so a little searching would likely provide useful comments - just saying?
    Check out the second post in THIS THREAD which was closed quickly because of the statement above; also, check out this APPLE SUPPORT ARTICLE - welcome aboard!
    110082
    34 times
    Oct 2011
    Upstate, NY
    818
    Here is what to do:
    For regular charging, its fine to charge it anywhere from around 20% through 40% - the exact percentage isnt important. Always go back to 100% before using it again. Then, once a month or say every 15 or so charges, let it run out, like down to 5% or less and then fully charge it. This act will calibrate the meter which is worthwhile. Most batteries do better when charged using this guideline.
  1. I am so confused !!!!
    By traceykate in forum iPad Apps
    Last Post: 10-13-2011, 02:56 AM
  2. Replies: 7
  3. I am confused about 3G and GPS...
    By Futurebird in forum iPad 2 Forum
    Last Post: 03-13-2011, 01:22 AM
  4. Confused about VPN
    By jojee33 in forum iPad Hacking
    Last Post: 01-16-2011, 10:28 AM
  5. Confused
    By aguilafan in forum iPad General Discussions
    Last Post: 04-21-2010, 07:50 PM
deep discharging an ipad
ipad charging is it better to run down battery
ipad2 do i need to let the battery run out
should i let battery run completely run out before charging
should i let my ipad battery run down
should i let my ipad battery run down before charging
should i let my ipad battery run down before charging?
should i let my ipad battery run down before recharging
should i let my ipad battery run down completely before charging
should i let my new ipad's battery run down before first charging
should i run down my ipad battery
should i what's the battery in my ipad rundown
