Is there a way?
This is a discussion on Is there a way? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Guys, is there a way to transfer photos from my PC to my Ipad 2 without using iTunes? Currently I can't synch my iPad with ...
Results 1 to 7 of 7
Thread: Is there a way?
    119137
    Oct 2011
    Costa Rica
    Question Is there a way?
    Guys, is there a way to transfer photos from my PC to my Ipad 2 without using iTunes? Currently I can't synch my iPad with iTunes but I need to transfer some pics so I'm wondering if there is a file manager that could work with iPad 2 iOS5?
    iPad Ninja
    49414
    80 times
    North Carolina
    1,925
    Hi MaynorPhoto - welcome to the forum!
    Well there are plenty of options: 1) email photos to yourself, pick them up on your iPad, and then save to the device; 2) use 'cloud' options such as Dropbox or iCould if you have iOS5 on your iPad; and 3) likely others that will be mentioned by future posters?
    BUT, you must explain your issue about not sync to you computer w/ iTunes - this may be the more important problem to correct - not sure? Let us know!
    119137
    Oct 2011
    Costa Rica
    Hi thanks Well, it is not really an issue but here it is the reason why I can't synch right now. Happens that I am located in Costa Rica and although I have the Netflix service in CR, happens that Netflix app is not available in our local App Store so I can't download it. Then a friend of mine who has a US account downloaded it and installed it on my iPad but obviously I can't synch otherwise will lose the Netflix app which I don't want (at least until JB is available) so there you go, that's why I can't synch yet.
    Problem is that I'm a photographer so need to transfer a bunch of pics so that's why I'm looking for options. Thanks for your reply btw ;-)
    iPad Wizard
    49745
    370 times
    6,597
    You could buy a camera connection kit.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,925
    Hi again - do you have iTunes on your computer sync to your iPad? Not sure what your Netflix issue is about but iTunes is the program needed if you want to transfer images from your computer to your iPad.
    If you indeed have iTunes setup correctly and sync to your iPad, my suggestion would be to put a folder in your 'Pictures' (or other name) directory on Windows Explorer - sub-folders (depending on your projects and/or photo collections) can be easily added - when sync w/ your iPad check off the 'new' folder (mine is named 'Ipad Pics') - the images you place in this specific checked folder (and sub-folders) will then be sync to your iPad - hope this helps? In not, please post back for further suggestions - good luck!
    Banned
    116351
    Oct 2011
    10
    Go ues iExplorer!
    19774
    Nov 2010
    Fort Walton Beach, FL
    The app Photosync is great and you can download a desktop app for Mac and or PC
    Ipod 40 lost on plane, ipod 80 as replacement, ipod nano, Macbook, Ipad and Ipad2, new MacBook pro. Verizon IPhone 4
best photo file manager on ipad 2 not through itunes
copy photos from pc to ipad without itunes
copy pictures to ipad without itunes
help to transfer photo to ios5 ipad2 without itune
how to sync picture from computer to ipad2 without itunes
how to tranfer photos from ipad2 to macbook pro without syncing
iexplorer
iexplorer ipad -microsoft -jailbroken
netflix for ipad 2 no os5
transfer photo from pc to ipad without itunes windows explorer
transfer photos from computer to ipad no itunes
transfer pictures from pc without itunes to ipad
Tags for this Thread
