My iPad 2 won't connect to WiFi
This is a discussion on My iPad 2 won't connect to WiFi within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi, I've had my iPad 2 for about 6 months and it's worked perfectly, but since last night, it suddenly won't connect to WiFi. I ...
Results 1 to 5 of 5
    95461
    Sep 2011
    6
    Hi,
    I've had my iPad 2 for about 6 months and it's worked perfectly, but since last night, it suddenly won't connect to WiFi. I thought it was a service outage until I realised my MacBook is connected.
    Anyone with a simply-explained solution for a non-techie user? HELP!!
    110082
    34 times
    Oct 2011
    Upstate, NY
    824
    Did you recently do any software updates to the iPad? Any chance some settings got mucked up? Its worth checking the obvious things first. Also, its worth "reconnecting" to your router. Go into Wifi settings and choose your current network. Select "Forget this network" or something like that. Then, restart the iPad. After it comes back up, go back into Wifi settings and "find" your network again and connect to it like you did when you first setup the iPad. Try a few other wireless devices too if possible and make sure they all connect.
    Just some suggestions.
    61094
    6 times
    Jun 2011
    271
    Reboot the router as well while you are at it. It's always a good thing to do from time to time.
    iPad Ninja
    49414
    80 times
    North Carolina
    1,928
    Agree w/ the above, i.e. try to re-establish your Wi-Fi connection as suggested; if not successful then try to 'Restart', and if not helpful, then 'Reset' the iPad - Directions HERE - these simple maneuvers often resolve many problems w/ the iPad.
    If none of the above helps, then I would suggest 'power recycling' your modem and router, i.e. turn off or pull the power plugs on both devices (or one if you own a combo unit); then sequentially power up the modem and then the router - if not successful, please post back here for additional advice - good luck!
    95461
    Sep 2011
    6
    Thank you all! It's connecting now! I rebooted my modem & router and that got my macbook connecting to wifi again, but my iPad wouldn't connect. I had tried reconnecting to my router a few times, but I wasn't restarting my iPad in the process. Thanks heaps!
  1. ipad 2 will not connect to wifi
    By gcclubs in forum iPad 2 Forum
    Last Post: 01-07-2013, 04:26 PM
  2. New Ipad. Cannot connect to Wifi
    By 06nbrnhill in forum iPad Help
    Last Post: 08-24-2011, 01:53 PM
  3. Ipad 2 won't connect wifi after activate the 3G
    By caparuni in forum iPad Help
    Last Post: 06-13-2011, 01:16 AM
  4. ipad won't connect to home wifi now
    By yorky48 in forum iPad Help
    Last Post: 04-11-2011, 09:13 AM
  5. How do you connect Wifi speakers to ipad
    By macfoot in forum iPad Help
    Last Post: 12-23-2010, 11:10 AM
ipad 2 won't connect to wifi
ipad 2 wont connect to wifi
ipad suddenly won't connect to wifi
ipad won't connect to wifi
ipad wont connect to wifi
megabus wifi ipad
my ipad 2 wont connect to wifi
my ipad wont connect to wifi
my ipad2 will not connect to wifi
why won't my ipad connect to wifi
why wont my ipad 2 connect to wifi
why wont my ipad connect to wifi
