How to project ipad 2 without cables
This is a discussion on How to project ipad 2 without cables within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello all, I would like to know if there is a way to make a presentation with keynote in an ipad 2 in a projector ...
Results 1 to 5 of 5
    119752
    Nov 2011
    Hello all,
    I would like to know if there is a way to make a presentation with keynote in an ipad 2 in a projector without using a cale, maybe using my iphone 4 hotspot as a wirelless network to all devices that might be necessary.
    See ya!
    14255
    14 times
    Sep 2010
    Berlin, Germany
    218
    Hi, I am not quite sure whether I fully understand your question but here is what I do.
    I set up a wifi network with the help of a mi-fi access point (huawei or some such, your iPhone 4 hotspot might do as well). Then I use an Apple TV which is wired to a projector. With the help of Keynote and the iPad I can wirelessly present and walk around while having full control over my presentation. Does this sound reasonable to you? So I go wireless from iPad to Apple TV and wired from Apple TV to the projector. Maybe there are wireless beamers available on the market which can do better than my setting. And of course I need power connections for Apple TV and projector.
    Hope this helps.
    Knut
    119752
    Nov 2011
    Hi,
    It is exactly what i need, but i donīt have an Apple TV device so i need to do this process from Ipad to a notebook...
    Thanks for your response!
    Rafael
    87727
    Aug 2011
    Florida
    12
    Quote Originally Posted by Kricke View Post
    Hope this helps.
    Knut
    I really need your help. If I use a small mobile hotspot device and Apple TV, I can wirelessy project my IPAD to my projector? No Router, just the mobile device, maybe even my phone as a hotspot? You initially note: "I set up a wife netword with help of a mi-fi access point"; please explain the set up, or rather how, specifically, do you set it up?
    14255
    14 times
    Sep 2010
    Berlin, Germany
    218
    Ok, first things first.
    You need to have a wireless LAN. But you do not need Internet access. With the help of a mi-fi device, which usually serves two purposes - one to access the Internet over a 3G (UMTS) connection and two to distribute this Internet connection to the wirelessly attached devices, I set up a wireless LAN.
    Normally, the mi-fi connects to the Internet, and passes the info through to the devices. This is mostly done with internal IP addresses, roughly speaking. For the presentation part of the setting, we do not need the Internet connection. So my iPad connects via AirPlay to the Apple TV. And as I wrote above the Apple TV is hooked up with a cable to the projector.
    As far as the set up of the hotspot (mi-fi device) is concerned please consult its manual. Everything should be explained there.
    Hope this clarifies it.
    Knut
  1. ipad/ipod cables
    By texaslonghorn in forum iPad Hacking
    Last Post: 10-10-2012, 05:36 PM
  2. Question about data cables vs data/charging cables
    By mediaman09 in forum iPad Help
    Last Post: 07-27-2011, 05:19 AM
  3. How to Project off Ipad with HBO Go to TV
    By blaskot in forum iPad General Discussions
    Last Post: 06-03-2011, 06:26 PM
  4. Replies: 2
    Last Post: 12-01-2010, 11:15 AM
  5. Ipad cables
    By trugrip in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-01-2010, 07:07 PM
can i project what is on my ipad to my tv?
can keynote in ipad wirelessly project
can you project ipad to tv
how to connect ipad to tv without cable
how to project a ipad on tv
how to project ipad on tv
how to project ipad to tv
how to project my ipad on ipad tv
how to project with ipad 2
ipad wifi project to samsung tv
project ipad on tv
project ipad to tv
