wierd printing question
This is a discussion on wierd printing question within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have a brand new brother printer. When i print from laptop with cable colors and print is normal and very good but printing wifi ...
Results 1 to 4 of 4
    118305
    Oct 2011
    new york
    I have a brand new brother printer. When i print from laptop with cable colors and print is normal and very good but printing wifi from my ipad 2 it is faded and looks like ink is low . would this be normal because its wireless ? I'm going to buy air print printer i've wasted a whole day buying apps and trying differant set ups . I can get it to print but to many steps and doesnt print all stuff. I'm not real good with this stuff i know thats part of the problem. Gotta be something easier.
    1522 times
    Walla Walla, WA
    15,430
    It's probably just the settings in whatever app you are using to print with. The app will have it's own printer driver, which will probably be somewhat generic and unable to adjust for the printer. Below is some info on the current state (to the best of my knowledge) of iPad printing.
    ____________________
    Some printers are directly compatible with AirPrint on the iPad. This includes several HP printers and a smaller selection of Canon and Epson printers. Be absolutely certain the printer supports AirPrint before buying. Some printers may require a firmware update to work. These are usually available on the manufacturers site. If you get this kind of printer you can print directly from within apps that support the feature, which is many.
    iOS: AirPrint 101
    Of course some of us already have printers and do not want to buy a new one. There are a couple ways to do this.
    One is to use a printing app on the iPad.
    Most (or all) other print apps can only print pictures and/or files that have been copied to that app via Open In or other method. Print n Share used to be able to print from AirPrint enabled apps if it was loaded the background. It lost this ability with iOS 5. It may still work with iOS 4 if you get it before the app is updated in the App Store.
    The second method is to load a program on the computer that will emulate an AirPrint compatible printer. Your computer must be on and have the printer available to it. The cheapest (free) is Airprint Activator. More features can be had with FingerPrint (mac and windows) and Printopia (mac only).
    There is a third way. A few printers (mostly HP's again) can be set up with their own email address. PDF attachments can be sent via this address to be printed. The last review I saw (several months ago) said it could be quite slow (big files not recommended), and sometimes the emails got lost and never printed. The advantage was that you could literally send/print from anywhere you have an internet connection.
    92259
    Aug 2011
    Mead WA
    23
    I went through the apps for printing and never could get any to work right. Staples had the HP 5514 all-in-one air print for less than $100 so I picked one up last night. Works great with the iPad2. The iPad finds the printer and displays it when you want to print, Touch it and then print and away you go. I should have done that before as it would have saved a lot of time and head scratching.
    113246
    Oct 2011
    Massachusetts
    47
    Glad the problem is solved. I also have an HP and am able to the HP Eprint as well as AirPrint.
    IPAD 2 Black 16 G WiFi + 3G
  1. Printing Question
    By Bingoldsby in forum AirPrint
    Last Post: 04-04-2012, 06:47 PM
  2. Printing
    By Laurieth in forum iPad General Discussions
    Last Post: 10-07-2011, 06:00 AM
  3. Wierd finger touch display
    By Mjmoore17 in forum iPad Hacking
    Last Post: 08-03-2011, 04:53 AM
  4. Printing help
    By mikewigan in forum AirPrint
    Last Post: 05-18-2011, 02:34 PM
  5. Replies: 8
    Last Post: 03-27-2011, 12:44 PM
airprint hp5514
hp 5514 airprint
hp 5514 airprint not working
hp 5514 ipad
hp5514
hp5514 review
hp5514 reviews
hp5514e
