ipad 2 not charging
This is a discussion on ipad 2 not charging within the iPad 2 Forum forums, part of the Apple iPad Discussions category; My iPad 2 charged perfectly for 2 months, then started only charging at full charge speed intermittently but would still slowly charge (no charging indicator), ...
Results 1 to 7 of 7
    113830
    Oct 2011
    Antigua and Barbuda
    ipad 2 not charging
    My iPad 2 charged perfectly for 2 months, then started only charging at full charge speed intermittently but would still slowly charge (no charging indicator), and now is not charging at all. During the period of charging problems it has only been recognized once by my Macbook, and now not at all. I am using the supplied charger, the supplied cable, and have also tried various other cables including a Griffin cable and car charger meant for the iPad.
    I have looked at my old iPad 1 internal dock connector (I never had charging problems with my iPad 1) and it is silver in appearance and I can see the "teeth" clearly. My iPad 2 internal dock connector is black and I cannot see the teeth.
    I don't know if that can be the problem.
    Any suggestions?
    114145
    Oct 2011
    6
    I would restore your iPad.
    First back up then restore from back up.
    13576
    1451 times
    Aug 2010
    Western NY state (USA)
    11,061
    Are you plugging the iPad into the wall socket? That's the best (and most efficient way) to charge the iPad. Yes, some newer Macs will do a full charge on the iPad - but Apple still recommends wall charging.
    If not that, and if you've tried other cables, then sorry, but I've no idea.
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    If the problem has been getting progressively worse it does sound like you may have a damaged pin or two, particularly if the Mac won't recognise it, or at least only very intermittently.
    I suggest a quick trip to your nearest Genius Bar. I'm sure they'll replace it for you.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    113830
    Oct 2011
    Antigua and Barbuda
    Thanks for the suggestions.
    I am trying to charge my ipad with the original charger and cable to the outlet.
    I would try to backup and restore the ipad but for the fact that it won't sync.
    I am still puzzled by the appearance of the internal dock connector. Can anyone out there have a look at their internal dock and say how it looks.
    Thanks.
    13576
    1451 times
    Aug 2010
    11,061
    As far as I can tell, the two iPads I have here have the same appearance you describe. The iPad1 has a silver part inside it, while the iPad2 has black.
    Hope that alleviates some concerns.
    106191
    Oct 2011
    63
    You can use a torch to see the condition of pins easily. If they are ok then change the cable. You can also measure the voltage at the outer two points of charger's USB port. If it is dc 5 volt then charger is ok.
  1. Charging the iPad
    By pdhughes1 in forum iPad Help
    Last Post: 09-20-2011, 03:58 PM
  2. Charging the ipad
    By jonho in forum iPad 2 Forum
    Last Post: 09-07-2011, 04:11 AM
  3. Ipad not charging
    By bsamimi in forum iPad General Discussions
    Last Post: 08-13-2011, 02:21 PM
  4. Replies: 7
  5. ipad not charging
    By Matt cooper in forum New Member Introductions - Site Assistance
    Last Post: 02-11-2011, 10:42 PM
ipad 2 charging problems
ipad 2 not charging
ipad 2 not charging problem
ipad intermittent charging
ipad not showing the carger indicator
ipad2 not charging
my ipad2 is not charging
why is my ipad 2 not charging
