I am stuck in Itunes store
This is a discussion on I am stuck in Itunes store within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I was looking in the itunes store and cannot get back out of it to go to my itunes - I know this sounds crazy, ...
Results 1 to 7 of 7
    111937
    Oct 2011
    California
    8
    I was looking in the itunes store and cannot get back out of it to go to my itunes - I know this sounds crazy, but I am really stuck in the store. Can someone please tell me how to get back to my itunes with my stuff in it, wanted to try and play a video just added to it from my computer. I have turned the ipad off and back on and no matter what I do I stay in the store - HELP
    Thanks to anyone, Darlene
    iPad Ninja
    62473
    69 times
    Jun 2011
    1,631
    The iTunes app is the shopping app. Music and Videos are where you play your purchases on iOS 5. The iPod app on earlier versions...
    iPF Super Guru
    40746
    99 times
    NW Left Coast
    3,504
    Quote Originally Posted by Darlene7 View Post
    Are you saying that you opened the iTunes Store App on your iPad and when you touch your home button your iPad does not return to the home screen? If you press the home button twice does the iTunes App icon appear at the bottom? If so, tap and hold the icon until it jiggles, then tap the circled minus sign in the upper left-hand corner. This will close the app (same goes for any other open apps).
    If that doesn't do it I would try resetting your iPad. Press and hold the power button and the home button together for at least ten seconds, until the Apple logo appears. It'll take a short time to boot up. See if that doesn't cure the issue.
    More here:
    iPhone, iPad, iPod touch: Turning off and on (restarting) and resetting
    As thewitt mentioned, you can play music from the iPod/Music App and videos using the Videos App.
    111937
    Oct 2011
    California
    8
    Thanks thewitt, I finally realized that later last night and really felt stupid, so use to my windows and apps are a big learning curve. With this forum and help from others I have been learning a lot the last 24 hours about using the Ipad and I really do like it a lot - hope they eventually come out with an app to watch Fox News live streaming, right now it won't work because of the flash in their website I guess. Thanks for your help, appreciate it, Darlene
    iPad Ninja
    62473
    69 times
    Jun 2011
    1,631
    Happy to help. Don't worry about feeling stupid, it happens to all of us
    113763
    Oct 2011
    I can't find music category in iTunes but podcasts and itunesu is there. More over when I connect to iTunes an error message comes saying can not connect to iTunes store
    111940
    Oct 2011
    17
    Should check if your country has iTunes store cause some not.
  1. Screen is stuck in itunes app
    By saflerl in forum iPad 2 Forum
    Last Post: 09-18-2011, 03:41 PM
  2. Apps Store - Category stuck
    By Boblins in forum iPad Apps
    Last Post: 08-21-2011, 08:29 AM
  3. App store stuck on 'loading'
    By Lockie34 in forum iPad Help
    Last Post: 08-01-2011, 08:11 PM
  4. itunes says im stuck in dfu mode
    By cales69 in forum iPad Hacking
    Last Post: 07-06-2011, 02:04 AM
  5. Stuck in the iBooks store?
    By cowenhirsch in forum iBooks
    Last Post: 01-20-2011, 10:00 PM
how do i exit itunes store on ipad
how do i get out of itunes store on ipad
how to exit itunes store on ipad
how to get out of itunes store
how to get out of itunes store ipad
how to get out of itunes store on ipad
ipad stuck in itunes store
stuck in itunes store on ipad
