I-Message two Ipad2's Iphone 4 same ID PLEASE Someone help....
This is a discussion on I-Message two Ipad2's Iphone 4 same ID PLEASE Someone help.... within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi Ive had my Iphone for a year and love it, we each have an Ipad 2 love it as well. We share the same ...
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By f4780y
Thread: I-Message two Ipad2's Iphone 4 same ID PLEASE Someone help....
    111926
    Oct 2011
    East Coast
    Hi Ive had my Iphone for a year and love it, we each have an Ipad 2 love it as well. We share the same Apple Id since we are in the same house and we can share apps. We upgraded all our devices to iOS5 and the i-message is causing some headache. Is it possible to have assign our other Ipad a new ID so the i-message will not interact with all devices? I cant find any info on that.
    Thank you
    108024
    Oct 2011
    Virginia
    47
    I think all you need to do is sign out of each device and iTunes then on iTunes on your device scroll all the way to the bottom and I think you can create a new account. Apps are no problem, when they need an update log off the new Id then log on the Id you bought the apps with and update, then log out and log back in with the new account. I did this with an app I bought on my wife's iPod and added the app to my ipad2.
    Hope this helps.
    108024
    Oct 2011
    Virginia
    47
    Yeah, double checked. Just log out of the current account. Then click sign in, the use existing or create new account options pop up. Click, create new. Then bingo bango bongo, ya got it.
    Oh, all this is some in the iTunes app on your device. The login button, is all the way at the bottom on the left, it will have your current id in the box.
    Good luck. Let me know how it goes!
    111926
    Oct 2011
    East Coast
    @TrxSlash Thank You
    We will be home in a few and I am excited to try this! Again Thank You
    Now if I could just get my Wifi Sync to work everything would be GRrreat!!!
    108024
    Oct 2011
    Virginia
    47
    Good luck. Pm sent.
    64212
    2 times
    Jun 2011
    36
    I had the same issue. The message I sent to a friend also showed as if I sent it from my wife's iPad. All I did was change the email address in the settings and kept the same ID. I hope this helps. I attached an image of what I mean.
    I-Message two Ipad2's Iphone 4 same ID   PLEASE Someone help....-image-2527266930.png
    Jamin - using original iPad 32GB
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    Yes, you definitely should not be changing your iTunes account to resolve this problem.
    It is a simple setting in the iMessage app, which you can get to through the main iPad Settings app. You just set up a different ID for each device and that is how you address them, just like dawz2 suggested...
    richsadams likes this.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    81426
    2 times
    Jul 2011
    50
    If you have separate email addresses then it can done quite easily, see below.
    How to Make iMessage Work Better Across Multiple Devices
    My significant other and I share and iTunes account (don't tell!), so after I updated my iPad and her iPhone, she started receiving all my iMessages. Whoops! Turns out, though, it's easy to associate different identities to different devices in iMessages, even if they share the same Apple ID—handy if you share an account with someone, have multiple iDevices of your own and want to set up separate buckets, or just want to change the address you send or receive message from (your "Caller ID"). Here's how.
    Associate a New Email with iMessage on Your Device
    1. Everything you need to do lives in the Messages tab of your iPhone, iPad, or iPod touch's Settings app, so launch Settings and tap on Messages.
    2. By default, iMessage will receive messages via your Apple ID email address and, if you have an iPhone, your phone number. That's why, for example, my wife was getting my iMessages. You can't remove an email address until you've replaced it, so from the Messages setting, tap Receive At > Add Another Email.
    3. Type in the new email address you'd like to associate with that device.
    4. Once the email's been entered, Apple will send a verification email to that address. When you receive it, just click the activation link and the new address will now be linked to that device.
    5. Finally, you can remove the original association by tapping the email address you want to remove and then tapping Remove This Email.
    Pretty simple, right? That took care of my problem (now my wife doesn't get my iMessages), associates her iMessage with her email address, and we can continue blissfully enjoying a shared iTunes account.
  1. Replies: 21
    Last Post: 10-01-2012, 08:57 PM
  2. Replies: 0
    Last Post: 10-11-2011, 09:06 PM
  3. iPhone 4S & ipad2
    By DavidM in forum iPad 2 Forum
    Last Post: 10-06-2011, 08:28 PM
  4. Replies: 1
    Last Post: 08-13-2011, 10:19 PM
  5. Yet ANOTHER newbie!.. ' Can't seem to be able to type message in the Message box...!
    By Starfish in forum New Member Introductions - Site Assistance
    Last Post: 04-13-2011, 04:46 AM
imessage goes to two phones
imessage going to 2 phones
imessage going to two phones
imessage multiple phones same account
imessage on two phones
iphone messages on two phones
message 2 ipod same apple id
twoo i phone messages
