problem withbthe update of some apps
This is a discussion on problem withbthe update of some apps within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi All suddenly my ipad doesn't allow me the update of some apps already downloaded (keynote, numbers, ecc) a message appears saying that the app ...
Results 1 to 10 of 11
    98056
    Sep 2011
    51
    Hi All
    a message appears saying that the app is not compatible with this ipad (??!!??)
    what does it mean? any precious help?
    thanks/fabio
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Have you upgraded to iOS 5, the latest iWork updates require this?
    98056
    Sep 2011
    51
    no, how can I do that?
    110646
    Oct 2011
    Hi there,
    I have iPad 1 and I have the exactly the same problem. Can anyone tell me if you definitely need to upgrade to iOS 5..... HELP!
    400
    Jan 2010
    12
    to update to iOS5, simply plug your iPhone or iPad to your MAC or PC. Once iTunes is up and running, it should tell you that an updated iOS is available, namely iOS5. However, I believe you should also update iTunes first, in order to make it all work with iOS5, you can do that by clicking on iTunes on the upper left corner of the window (with iTunes open) and click on 'Check for updates'....its a bit of a lengthy process, so just sit back and wait......I've updated my MacMini, iTunes, iPhone4 and iPad2...no problems at all and no issues with incompatible Aps...at least with the ones I use....
    And yes, iOS5 is compatible with the first gen iPad.
    98056
    Sep 2011
    51
    thank you
    is there a risk to loose the apps and all the documents already downloaded after the upgrade?
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Quote Originally Posted by fagani
    thank you
    There appears to be from reading the threads but mine went flawlessly, everything back where it should be......the only thing I have lost since getting my iPad is my mind!
    If you do lose them then apps can be re-downloaded for free. If you have important documents then I suggest putting them in Dropbox first so if the worst happens you can get them back.
    400
    Jan 2010
    12
    Quote Originally Posted by Gabriel1 View Post
    same here, absolutely no problems with all of my upgrades. Reading some of the threads here with people seemingly having all kinds of problems, really not sure why that is happening, unless there are more issues with Windows PC's than Mac's.
    I made sure that iTunes as well as my Mac were fully updated before I plugged my iPhone and iPad2 in to update, I do think it is critical to ensure that your Mac and PC are completely up to date with all software before plugging your iPhone/iPad in!
    For my MacMini at least, there were nearly 1G of updates in relation to iOS5!
    iPad Addict
    121
    87 times
    Jan 2010
    Seattle, Washington USA
    1,293
    Apple plugged nearly 100 "vulnerabilities" in iOS with iOS 5. Many apparently were related to editing of "foreign" (i.e. Microsoft Office) documents with Pages and Numbers. That suggests that the updates for those apps required support by iOS 5. In some cases, however, the "incompatibility" message was erroneous and may have been related to the deluge of upgrade requests that buried Apple's servers. I received the message, ignored it, and eventually the apps were updated before I successfully downloaded iOS 5 and updated my iPad.
    111214
    Oct 2011
    Clifton Forge VA
    There are definitely more problems with Windows PCs than Macs. I was unable to download 2 apps I purchased since updating iTunes and iPad (yesterday). I got error -50 on both of them when trying to download from my Windows XP laptop. Downloading from an iMac was flawless.
  1. update problem
    By czsysz in forum iPad Help
    Last Post: 09-21-2011, 01:03 AM
  2. Strange update problem
    By louisp in forum iPad Help
    Last Post: 09-04-2011, 02:16 AM
  3. ipad2 4.3.5 update problem
    By irbow in forum iPad Help
    Last Post: 08-14-2011, 07:28 AM
  4. Unable to download apps or update apps
    By Snowdropbooks in forum iPad Apps
    Last Post: 05-15-2011, 02:42 AM
  5. Problem with software update
    By MacClanIII in forum iPad Help
    Last Post: 04-21-2011, 07:55 PM
keynote app on ipad not updating
keynote problems after updating ipad
my ipad does not allow me to update applications
this app is incompatible with this ipad update
this app is incompatible with this iphone
troubles updating ipad apps keynote, pages, numbers
update not compatible with this ipad
will not update some apps
