Freezing ipad 2
This is a discussion on Freezing ipad 2 within the iPad 2 Forum forums, part of the Apple iPad Discussions category; So my iPad 2 keeps freezing and I've been to the apple store twice in two days. Yesterday I was told to restore back to ...
Results 1 to 3 of 3
Thread: Freezing ipad 2
    38642
    Philadelphia,PA
    42
    Freezing ipad 2
    So my iPad 2 keeps freezing and I've been to the apple store twice in two days. Yesterday I was told to restore back to factory settings and then sync. Well that didn't work. Today I was told that I had a bug in my software and it should be fixed when ios5 comes out. They ran a hardware diagnostics and nothing came up so they said it was a software issue.
    116 times
    15,249
    38642
    Philadelphia,PA
    42
    Thanks but I've done most of those things. They even did it in the store.
  1. iTunes Freezing
    By Tom P. in forum iPad 2 Forum
    Last Post: 10-27-2011, 02:04 PM
  2. 1st generation IPad FREEZING
    By gdriussi in forum iPad Help
    Last Post: 09-13-2011, 03:26 PM
  3. Replies: 0
    Last Post: 03-24-2011, 05:15 PM
  4. Freezing when connecting
    By Jayjayphoto in forum iPad Help
    Last Post: 06-11-2010, 10:39 PM
  5. iPad freezing during video.
    By DLove in forum iPad General Discussions
    Last Post: 04-05-2010, 07:27 AM
ipad 2 keeps freezing
ipad keeps freezing
ipad keeps freezing internet
ipad keeps freezing up
my ipad keeps freezing
my ipad keeps freezing up
why does my ipad 2 freeze up
why does my ipad 2 keep freezing
why does my ipad keep freezing
why does my ipad keep freezing up
why does this game apps keep freezing up
why is my ipad freezing up
