Key clicks and sleep button sounds stopped working??
This is a discussion on Key clicks and sleep button sounds stopped working?? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; HI forum! recently my iPad stopped making the "clicking" sound when I type and also when I put it to sleep. I've noticed that other ...
Results 1 to 6 of 6
    51059
    May 2011
    8
    HI forum!
    recently my iPad stopped making the "clicking" sound when I type and also when I put it to sleep. I've noticed that other sounds are missing like email alerts. I made sure that the sounds were turned on in the settings menu, but they still don't work! I can listen to music and video with no problem, just not these sounds i mentioned. Any ideas??
    116 times
    15,249
    You have activated the Mute function - either by the hard switch by the side of the volume control or the soft switch at the far left of the multi-task bar. It's easily done. The function is re-assignable between the two locations in the Settings menu. So check that this function has not been activated and all should be OK.
    51059
    May 2011
    8
    Worked like a charm, thanks so much!
    116 times
    15,249
    No problem - have a great day!!
    127392
    Nov 2011
    colchester
    hello..I too have this problem and I can't resolve it...I can't even find the place you suggest at the top left....am I dim...thanks in anticipation......
    127396
    Nov 2011
    Morecambe, England
    Quote Originally Posted by judithwalsh View Post
    Hi Judith - the slide switch you want is next to the volume buttons on the top left hand side when the Ipad is face down and you can see the Ipad logo and the text is at the bottom. The switch needs to be pushed towards the top of the Ipad. You need to check that under Settings, then General, that the option "use slide switch to:" is set to mute and then all should be well.
  1. Sleep/wake button not working
    By ritesh_akh in forum iPad Help
    Last Post: 11-14-2011, 03:56 PM
  2. App stopped working
    By tnbug in forum iPad General Discussions
    Last Post: 04-02-2011, 11:49 AM
  3. Ipad sleep/wake button problem
    By Biggerdjam in forum New Member Introductions - Site Assistance
    Last Post: 02-03-2011, 09:49 PM
  4. Replies: 16
    Last Post: 12-20-2010, 06:16 PM
  5. Why do they call it the Sleep/Wake button?
    By iPadCharlie in forum iPad General Discussions
    Last Post: 08-07-2010, 03:31 PM
apple ipad click button not. working
how do you make keys click on ipad
how to make keys click on ipad
ipad key clicks stopped
ipad keyboard clicks stopped
iphone key clicks stopped
iphone not making clicking sounds
iphone not making keyboard clicks
key clicks on ipad not working
keyboard noise when typing ipad not working
my keyboard clicks are not working
the sound on my ipad stopped working
