Ipad 2 loosing wi fi signal
This is a discussion on Ipad 2 loosing wi fi signal within the iPad 2 Forum forums, part of the Apple iPad Discussions category; My ipad2 is loosing wifi signal intermittently iPhone touch an 2 are all ok, any ideas anyone? Thanks...
Results 1 to 5 of 5
    88664
    Aug 2011
    116 times
    15,249
    Other Members who have suffered this problem have found that one of two things usually helps.
    First of all, reset the router.
    If that doesn't work, then go to 'Settings', 'WiFi' and tell the iPad to forget the WiFi settings.
    Then, when the iPad picks up the WiFi signal again, re-enter the settings.
    See if either of these helps; if not, don't hesitate to get back to us.
    88664
    Aug 2011
    I have tried these already, I will try again.
    116 times
    15,249
    If the problem persists, then a reboot of the iPad might help. Switch the iPad off and then hold down the Power and Home buttons until the white Apple logo appears; it might take a while, but the iPad will reboot.
    111690
    Oct 2011
    Uk
    I had this problem and all the above didn't work. Apple customer services couldn't sort it. Rang Sky ( my wifi provider) and after a few failed attempts, eventually changed the signal channel through my sky online. It worked. Apparently, on the old signal channel, the signal was intermittently being blocked. Don't know how it worked, but it did.
  1. Loosing sound
    By bentonc1 in forum iPad Help
    Last Post: 08-20-2011, 10:42 PM
  2. iPad Wifi Signal Strength
    By AQ_OC in forum iPad General Discussions
    Last Post: 05-19-2011, 02:06 PM
  3. Wifi loosing connection
    By Misho73 in forum iPad 2 Forum
    Last Post: 04-04-2011, 07:18 PM
  4. Replies: 2
    Last Post: 03-26-2011, 01:25 AM
boost home wireless signal for ipad
boot wifi signals on ipad
how to boost ipad 2 wifi
how to increase ipad 2 wifi reception
increase ipad 2 wifi range
increase ipad wifi range
ipad 2 loses aignal
ipad keeps on loosing wi-fi signal
ipad losing signal strength
ipad losing wifi strenght
ipad2 lost wifi reception
my ipad 2 is loosing wifi range
