Lock when closing the cover
This is a discussion on Lock when closing the cover within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi, I'm new at this forum.
I´m from Portugal, and last week i goot my ipad2
I have a doubt, the function "Close it and ...
I have a doubt, the function "Close it and the iPad is automatically disabled. Open it and iPad is activated instantly - no need to press any buttons" (lock when closing the cover) it only work's with smart cover? or any case that close the screen?
tkx,
best regards,
Ruben Teixeira
10-08-2011 01:05 PM
iPad Addict
It works with any cover that activates the sleep/wake function. If the cover includes magnets (like the SmartCover) , it works. Otherwise, not. If you're shopping for a screen cover other than the SmartCover, check its features. The ability to sleep/wake the iPad will usually be mentioned.
By the way, you titled the thread "Lock when closing the cover." That's not quite accurate. Closing the SmartCover puts the iPad "to sleep." It doesn't "lock" or even "disable" the iPad in any useful sense. You may, however, set a passcode (4 digits) that must be used each time the iPad "wakes." That will effectively "lock" or "disable" the iPad. It's a separate option in Settings. I don't mean to be pedantic. Just wanted to be sure you understand the functionality.
- You may not post replies
- You may not edit your posts
Forum Rules
By lukeskywalker in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 07-04-2011, 02:02 PM
By Joeleo1937 in forum iPad Apps
Last Post: 07-01-2011, 03:01 PM
By ifej434 in forum iPad 2 Forum
Last Post: 05-16-2011, 02:15 AM
By Jlocro in forum iPad General Discussions
Last Post: 04-01-2011, 03:00 PM
how come my ipad wont lock or unlock when i close the case
how do i set my ipad to lock when i close the cover
how does ipad cover lock work
how does ipad cover locks the ipad?
how does the ipad cover lock work
how ipad cover lock works
ipad automatic lock case
ipad click on closing cover
ipad cover doesn't lock
iphone 5 autolock cover
locking my ipad by closing my case
my ipad wont lock when i close the cover
