Case for Ipad leaving lines on screen?
This is a discussion on Case for Ipad leaving lines on screen? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello guys, Im new here so apologies if there has already been a thread like this one but I wondered if you could help? I ...
Results 1 to 4 of 4
    106255
    Oct 2011
    Northampton
    I bought a case for my Ipad 2 - its on ebay but it wont let me post a link? but its item number 280729499700
    and the problem is - I can see little lines going down the screen - not marks - they actually look like they are in the screen - if you see what I mean? As I cant wipe them off?
    I am worried its something to do with the magnetic strips in the cover?
    Any ideas?
    90362
    28 times
    Aug 2011
    Milwaukee, WI
    960
    That's possible. I know the official SmartCovers have been known to do that. I've had mine since 8/23 and I wipe my screen diligently and do not have any lines. I think the lines can form due to the magnetic strips and maybe opening and closing it excessively. I'm not sure there is much of a fix for the lines if they're already there, but look around the forum and see.
    46067
    Kansas USA
    94
    Just want to verify with the OP, are you saying these are lines that you cannot wipe off? Is this an Apple Smartcover? (I can't find your case with the numbers you provided.) If this is a Smartcover, there is a thread somewhere with photos, etc., about the cover hinge shedding metal dust. However, IIRC, the marks were dust that could be wiped away. Obviously, if your case or cover is causing damage, stop using it. There are many options out there for good protective cases. There's a huge thread discussing this subject. Just do a search.
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Well welcome to the forum @ OP -
    This topic as already mentioned has been covered in other threads - from your eBay reference number, I did a 'screen capture' which is attached - assume this is the 'Smart Cover' that you purchased - please confirm.
    I (and many others) own an Apple 'Smart Cover' and the 'lines' that you mentioned are a 'side effect' of this product - the lines form on the iPad screen where the flexible parts are connected, i.e. there is space that will allow presumably dust to accumulate - this is easily removed when needed; again, there are posts/threads on cleaning the iPad screen - I usually just lightly dampened a CD microfiber cleaning cloth but other 'safe' options exit.
    Bottom line - not to worry! Enjoy your iPad!
  1. screen black lines bars
    By federicom03 in forum iPad Help
    Last Post: 10-02-2011, 03:15 AM
  2. Smart Cover leaving lines on screen.
    By kilofox in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-21-2011, 10:27 PM
  3. Why matte screen protector have vague lines
    By mason123 in forum iPad 2 Forum
    Last Post: 05-10-2011, 09:44 AM
  4. Clock Apps and leaving iPad on all night
    By Zanvetto in forum iPad General Discussions
    Last Post: 02-25-2011, 08:57 PM
  5. leaving the iPad on while charging overnight
    By ivanmarkchang in forum iPad General Discussions
    Last Post: 11-13-2010, 08:59 PM
apple magnetic cover leaving lines
black streaks on ipad screen protector
case caused ipad stripes
how to remove lines on ipad screen
ipad case leaves marks on screen
ipad cases with lots of lines
smart cover causing black lines on ipad screen protector but not on the screen itself
stripes on ipad screen
