Safari locked up today
This is a discussion on Safari locked up today within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Just loaded all kinds of stuff on my Ipad2 and all of a suddent the safari screen shaded and I cant use it. Everything else ...
Results 1 to 9 of 9
Like Tree2Likes
  • 2 Post By twerppoet
Thread: Safari locked up today
    106751
    Oct 2011
    Tallahassee
    Just loaded all kinds of stuff on my Ipad2 and all of a suddent the safari screen shaded and I cant use it. Everything else on the device seems to be working. Any advice would be most appreciated!
    96140
    Sep 2011
    18
    Try totally switching off the device, ie. Power off, that should reset it, I think. Hope it works for you.
    1523 times
    Walla Walla, WA
    15,433
    With Safari closed: double tap the Home button to pull up the multitask bar. Tap and hold on any icon until they start to jiggle. Tap on the minus sign on the Safari apps icon. This will remove it from RAM, and insure the app a clean start the next time you open it. Tap the Home button again to exit.
    If that does not work a complete power down, as OsambaMark suggests should. Apple calls this a restart. You should probably do this once in a while anyway. Once a month is usually about right, or whenever the iPad starts to act strange.
    And if that does not work try a reset.
    It's very unlikely that one of these won't fix a Safari crash, but if they don't let us know.
    johannah and alan.styles like this.
    108719
    Oct 2011
    same issue...
    We are having the same issue - safari opens briefly and then closes. mail opens but as soon as you click a message it closes too. also we can not access the app store. have tried the suggestion mentioned - anything else we can do?
    45407
    35
    I have had the same exact problem before I got my new iPad.
    First try double clicking the home button to bring up the multi-tasking bar. Hold an app that appears in the multi-tasking bar and it will start to jiggle. Press all the little "minus'" to delete them and stop them from running. When you close an app, no matter what app it is, it will be running in background. So it is good to do this once in a while.
    If the problem persists restore your iPad. When your iPad is fully restored it will ask you if you want to use an old iPad back up. Pick "set up as new iPad" because if the problem was on the iPad, it will surly be on the backup.
    And if the problem still persists go to your local Apple store. Make sure to set up a Genius Bar Appointment because usually they will not have any open spots. Explain your problem and they most likely replace it for you. If they ask to see the problem them-selves, meaning see it frozen, try going on a website with a lot going on like ESPN.
    I hope you resolve your problem.
    Regards,
    Ralphy
    Owner of:
    iPod Nano 1st, 2nd, 3rd, & 6th Gen(s) 1, 2, 3 gens 4GB 6 gen 8GB
    iPod Touch 2nd Gen 8GB (lost)
    iPod Touch 4th Gen White 32GB
    iPad 2 32GB Black WiFi (sold)
    The New iPad "iPad 3" 32GB Black WiFi
    Late 2011 Macbook Pro 13" i5 2.4GHz 4GB Memory
    119 times
    15,248
    Quote Originally Posted by u038617 View Post
    Did you try both restart and reboot. They are entirely different operations as far as the iPad is concerned. If both really do fail to fix the problem and you've quit all the apps too, then a visit to the Apple Store is definitely on the cards...
    108719
    Oct 2011
    yes we tried both restart and reboot. thanks for both of your suggestions. we have tried the restore but like you said, restoring the old ipad did not fix it. we have not tried the new ipad selection because i was wondering if there was a way to save our content, pics, books music etc. or is it gone for good?
    108719
    Oct 2011
    fixed by using the new ipad selection.. used dropbox for pics. thanks for your help! hopefully they will come up with a fix that doesnt require this step.
    45407
    35
    What I next can suggest is wait for iOS 5 and iCloud. One they come out everything on your iPad will be pushed up into the cloud. So after iOS 5 and iCloud come out you will have no problems with getting a replacement iPad.
    Owner of:
  1. safari locked up
    By Watty82648 in forum iPad Help
    Last Post: 01-25-2012, 08:25 AM
  2. Locked out twice!!! How do I fix?
    By Stockmoose16 in forum iPad General Discussions
    Last Post: 11-15-2011, 11:16 AM
  3. Locked out
    By Hil in forum iPad Help
    Last Post: 07-11-2011, 12:13 AM
  4. Ipad is not locked but mail is locked
    By johndeflumeri in forum iPad General Discussions
    Last Post: 05-13-2011, 05:55 AM
  5. Locked sim
    By Dis2cruise in forum iPad General Discussions
    Last Post: 09-08-2010, 06:53 AM
ipad safari locked
ipad safari locked up
safari is locked up
safari is locked up on my ipad
safari locked
safari locked up
safari locked up on ipad
safari locks up
