Issues
This is a discussion on Issues within the iPad 2 Forum forums, part of the Apple iPad Discussions category; having some odd issues. My iPad 2 is only 6 months old. Sometimes it just goes completely unresponsive....touching the screen doesn't work...can't open & close ...
Results 1 to 7 of 7
Thread: Issues
    40726
    Michigan
    161
    Issues
    having some odd issues. My iPad 2 is only 6 months old. Sometimes it just goes completely unresponsive....touching the screen doesn't work...can't open & close anything. Today the screen was actually "flashing" whenever I touched it. Only thing that works is a complete reboot. I keep my programs closed. Why do you think this is happening? It's been twice in the past week. Thanks annette
    38516
    18 times
    Seattle
    555
    Could be a loose connection some where inside or bad hardware. Your best bet is to take it into Apple for an exchange.
    iPad 2 64GB Wifi 5.1.1 jailbroken
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Hi Annette - I assume that your iPad is not 'jailbroken'? But if so please post that fact - might be an issue?
    Now by 'reboot' do you mean that you simply 'restarted' your iPad (by using only the on-off button at the top right) or did you also 'reset' the iPad (involves pressing the on-off & home buttons simultaneously); if not already done, try the reset option - Directions HERE - none of your apps or your data will be lost by this maneuver - good luck and please post back if the problem persists -
    40726
    Michigan
    161
    Hi, no it's not jail broken....and I have re-set it. When I do the reset it totally fixes the problem....I've had to do this twice recently. I'm just wondering what's going on and what could be causing it. Is this something that can happen normally?? Thanks!! Annette
    Quote Originally Posted by giradman
    iPad Ninja
    49414
    80 times
    North Carolina
    1,930
    Quote Originally Posted by anmanwar View Post
    Well, since your iPad is still under its original warranty, I would agree w/ a previous poster, i.e. take the device into an Apple store if one is available near you or call Apple tech support - appears to be a hardware issue - good luck and please post your experience(s) - may help others.
    76661
    4 times
    Jul 2011
    Oregon
    272
    Annette,
    Have you installed any applications that are obviously inteneded for the iPhone?? That is, ones that only display in portrait view with small centered block and "2X" in the corner. There has been a lot of flap about some of those apps which the iPad might not like and can cause some unexpected malfunctioning. Just a thought.
    Also, do you remember what you were doing and with what applications at the times the thing has messed up?
    Brian - Sent from my iPad using iPF
    Brian
    (sent from my iPad)
    40726
    Michigan
    161
    Brian, yes...come to think of it my daughter put 2 of her iPod touch apps on my iPad! I have seen the small screen you speak of. I'm gonna delete app and see if that helps. Thank you!! Annette
  1. Issues with 4.3.2 JB.
    By NLAlston in forum iPad Hacking
    Last Post: 04-21-2011, 01:43 AM
  2. WI-FI issues
    By jag123 in forum iPad Help
    Last Post: 04-07-2011, 11:13 AM
  3. VGA TV issues
    By shanshuprophecy in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-20-2011, 05:33 AM
  4. Wi fi issues
    By Imspartacus in forum iPad Help
    Last Post: 08-15-2010, 01:23 PM
ipod blinking apple doesn't start
