Verizon 3G issues
This is a discussion on Verizon 3G issues within the iPad 2 Forum forums, part of the Apple iPad Discussions category; This is driving me nuts! 3G randomly drops out and I have to toggle airplane mode a couple time to get it back. I'm on ...
Results 1 to 4 of 4
    38512
    31
    Verizon 3G issues
    This is driving me nuts! 3G randomly drops out and I have to toggle airplane mode a couple time to get it back. I'm on 4.3.4. Wasn't this issue supposed to be fixed in 4.3.2? Any help is appreciated, thanks guys!
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Sorry to hear about your dilemma, Simply restarting the iPad can fix most issues. Hold down the power switch (outside edge) by itself until the red slider appears. Turn it off by sliding the switch and then once again hold down the power switch until the Apple logo appears.
    Resetting the iPad should be reserved for a non-responsive unit as it addresses other activity but if restarting doesn't do it, resetting it might. Hold down the power and home buttons until the slider appears and shut it down. Hold down the power switch again until the Apple logo appears. Fully booting up from a reset will take a little longer than a restart.
    More here:
    http://support.apple.com/kb/HT1430
    Let us know if that helps. Others may have some more suggestions as well.
    38512
    31
    Yea, I may have to reset, as this problem never resolved itself no matter how many time I rebooted. Can anyone with a Verizon 3G ipad2 confirm they do NOT have his problem? Thanks,
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Quote Originally Posted by Ipadgk View Post
    FWIW it sounds like you may be confusing "resetting" with "restoring". Resetting won't change any settings or lose any data, apps, etc. I'd certainly give that a try. Restoring basically returns the iPad to as-new condition so everything would have to be downloaded and set up again. That would be a last ditch effort.
  1. VERIZON or AT&T
    By bcilia in forum iPad Carriers
    Last Post: 05-25-2011, 07:34 AM
  2. at&t or verizon?
    By ercsliberty in forum iPad Carriers
    Last Post: 05-21-2011, 07:16 AM
  3. ATT or Verizon??
    By Marty in forum iPad Carriers
    Last Post: 04-12-2011, 10:44 PM
  4. verizon vs ATT
    By mfruin in forum iPad Carriers
    Last Post: 11-25-2010, 10:19 AM
  5. I can Wi-Fi Verizon...
    By Wetstuff in forum iPad General Discussions
    Last Post: 10-04-2010, 01:31 PM
ipad verizon 3g dropping
problems with verizon 3g
verizon 3g constantly sroppung
verizon 3g dropping
verizon 3g dropping out
verizon 3g randomly drops out
verizon articles about problems with 3g
verizon drops me from 3g
verizon in 3g from airplane
verizon ipad 3g problem
verizon ipad2 drops 3g
verizon randomly dropping out
