Is there a way to keep the iPad from shutting down while playing iPod music?
This is a discussion on Is there a way to keep the iPad from shutting down while playing iPod music? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I don't want to set Auto Lock to Never because I will forget to change it back. When I am playing music through the iPod ...
Results 1 to 10 of 16
    17568
    Oct 2010
    I don't want to set Auto Lock to Never because I will forget to change it back. When I am playing music through the iPod App the iPad locks and shuts down the music. Is there a way to set the iPad to not lock when playing the iPod App only?
    72622
    27 times
    Jul 2011
    toronto
    816
    the music will keep playing for the iPod app, only videos are disturbed.
    what iPad do you have?
    what firmware?
    although those answers are not relevant, you shouldn't have this issue.
    Waiting for that “Next Thing” means you’d never buy anything.
    17568
    Oct 2010
    Poser,
    Thanks for the reply. I have an iPad2 running the latest version of the software 4.3.5 (8L1).
    72622
    27 times
    Jul 2011
    toronto
    816
    Quote Originally Posted by Prozit View Post
    Poser,
    ok....so what are you saying, if you play a track, and press sleep(top button), the music stops?
    if i play a track(or playlist), and press sleep, my music keeps playing.
    or if i press the home button(circle), my music keeps playing.....while i am in another app too.
    the only way my music will stop is....if i press "stop" playing, start a video or the battery dies.
    280739
    Feb 2013
    Minnesota
    At the risk of reviving an old thread.. When I am playing music the iPad locks and shuts down the music... this never used to happen, until a recent iTunes update. Cannot see how these are related. but the only thing that changed.
    It used to play music and when Auto Lock kicked in just blank out the screen.. now it stops the music..argh.. little help..please?
    TIA, - Nicodemus555
    iPad Wizard
    49745
    369 times
    6,587
    Quote Originally Posted by Nicodemus555 View Post
    TIA, - Nicodemus555
    What app are you using? With iOS 6, Apple quit letting music play on YouTube once iPad is in sleep mode.
    But under iOS 6, music continues to play if you're listening via the native music app, Amazon's Cloud Player, TuneIn Radio, Pandora, Downcast and more. It also lets Audible audiobooks and white-noise apps play on even with iPad in sleep mode.
    Moderator
    131244
    605 times
    Dec 2011
    Regina,Canada
    14,383
    TIA, - Nicodemus555
    Are you streaming music over the Internet? If you are, the iPad shuts off WiFi when it goes to sleep, unless the charger is plugged in.
    110082
    34 times
    Oct 2011
    Upstate, NY
    819
    Quote Originally Posted by scifan57 View Post
    Are you sure about that? As soon as you wake the iPad the wifi is right there and ready to use. It doesn't seem to need to reconnect to whatever. Hmmmmm?
    32GB Wifi iPad 2 / OS 6.0
    Moderator
    131244
    605 times
    Dec 2011
    Regina,Canada
    14,383
    Quote Originally Posted by s2mikey View Post
    It's a battery saving feature. The WiFi should disconnect unless it's being actively used, such as for streaming music.
    iPad Wizard
    49745
    369 times
    6,587
    Quote Originally Posted by Kaykaykay View Post
    My iDevices continue to play music on apps I mentioned (even while streaming while in sleep mode). I can turn on Pandora and put my iPads into sleep mode and keep listening, for instance. No plugging in is needed. The only app that no longer works that way AFAIK is YouTube, and that happened with iOS 6.
  1. Replies: 2
    Last Post: 07-01-2011, 01:33 AM
  2. Question about playing music on the ipad 2
    By GAMESHARQ in forum iPad Apps
    Last Post: 06-01-2011, 12:16 PM
  3. Replies: 1
    Last Post: 03-19-2011, 10:12 PM
  4. Any way to get iPod popup when music isn't playing?
    By 0sync0 in forum iPad Hacking
    Last Post: 08-22-2010, 07:13 PM
  5. Playing local iPad music on stereo via AirPort Express
    By Canuck in forum iPad General Discussions
    Last Post: 08-22-2010, 01:25 AM
how do i keep ipad from shutting down while streaming
how to stop ipad from cutting off music
ipad music stops when locked
ipad music stops when sleep
ipad music turns off
ipad stops playing music when locked
ipad stops playing music when locks
ipad stops playing music when sleeps
is there a way to keep playing music on ipad
music stops playing on ipad when locked
music stops when ipad sleeps
why does ipad stop playing music when sleeping
