Results 1 to 2 of 2
    99048
    Sep 2011
    canada
    Unhappy Send email problem
    Prepared an email to send as I have done many times before, this time when I pressed send the spinning circle beside the iPad signature kept spinning and there was no whistle sound indicating it had been sent. So I assumed my wifi connection had been lost, so I shut down my ipad [slide to power off] so my ipad would reboot the wifi connection when it turned on again which it did, but my prepared email to be sent was gone. What happened and how can I prevent this from happening again ??
    622 times
    Dayton, WA
    13,312
    Tap the Mailboxes button at the top left of the email list. If you see an Outbox (will only be there if there is a pending email), you can go into it and retrieve your non-sent email.
    It also might be in the Draft folder, waiting for you to try and resend it. To see the draft folder, again tap the MailBox button, then go down to your account (instead of the Inboxs at the top) and choose it. You should then see all the standard email folders; Trash, Sent, Draft, etc.
    If it isn't in the Sent, Draft, or Outbox, then it's probably gone for good.
  1. Can't send email
    By kategalway in forum iPad Help
    Last Post: 05-23-2011, 07:43 AM
  2. Email will not send
    By Mbrown62 in forum iPad Help
    Last Post: 04-13-2011, 09:19 AM
  3. How To Send PDF Attachments in Email?
    By DUTCH VanAtlanta in forum iPad General Discussions
    Last Post: 04-09-2011, 09:13 PM
  4. Email won't send
    By Dancemom in forum iPad Help
    Last Post: 02-03-2011, 02:40 PM
  5. Help - the email send does not work
    By arnielh in forum iPad Help
    Last Post: 07-28-2010, 03:51 PM
cannot send or cancel from draft folder ipad
how to get out of draft on ipad
ipad 2 won't send email
ipad 2 wont send email
ipad 2won't send email
ipad mail slow spinning circle
ipad problem sending email
ipad send email problems
ipad won't send email
ipad won't send emails
ipad2 emails won't work
ipad2 won't send emails
