Results 1 to 6 of 6
    62587
    Jun 2011
    12
    HELP - iTunes not showing apps; afraid now to sync to i[ad2
    I had to do a fresh install on my computer to setup a Windows 7 PC (and of course took backups)
    Status quo is this:
    • I can see ipad apps in Windows explorer
    • Itunes is pointing to that directory
    • I still have all my apps on the pad, but
    • I see no apps in itunes
    I had to reinstall winddow 7 a few times, and everytime I reintalled itunes it all came back to life. This time, same process, but for some reason, I see no apps.
    If I double click any an app file in windows explorer, that app will show up in iTunes. Very strage. Should I double click on each app??
    Not sure how to move forward. I do not want to sync my ipad and i'm sure it well get clearef out.
    I also have an issue with Activate/Deactivate this compter. in my previous troubleshooting to date, I used up some actications- I only have two shots leflt. Both menu itesm are available.
    Any suggestions??
    Let me ask this.. how do I contact Apple by email if I get in real trouble?
    Attached Thumbnails Attached Thumbnails HELP - iTunes not showing apps; afraid now to sync to i[ad2-itunes-02.png   HELP - iTunes not showing apps; afraid now to sync to i[ad2-itunes-03.png
    91324
    Aug 2011
    United states
    128
    I searched the related forum.
    here you may get your answer:
    Apps not showing up on itunes
    62587
    Jun 2011
    12
    ok,I uninstalled and re-installed but I need to know two things before I can fix this:
    1) Can someone please post a screen shot of the direcroty structure beneath iTunes. Mine is entries are messed up.
    2) Can someone please advise what the last subdirectroy is supposed to be in the path? iie \iTunes or \iTunes\Media etc etc .
    Attached Thumbnails Attached Thumbnails HELP - iTunes not showing apps; afraid now to sync to i[ad2-1.png   HELP - iTunes not showing apps; afraid now to sync to i[ad2-2.png
    62587
    Jun 2011
    12
    Thans apple 2001.
    I found the structurd , and I see they changed the strucutre in later upgrades just to make this all the more frustrating.
    Ref: https://discussions.apple.com/thread...art=0&tstart=0
    Slowly rebuiliding things to get it to work ; they make it so unnecesarrily convoluted and difficult.
    62587
    Jun 2011
    12
    After a re-install and some file/folder movement, I now have the right structure and I can see my apps in itunes. But I can see how it will arrrange them as I have not connected the ipad yet.
    Where does iTunes store the screen layout?
    I have all my apps nested in menus....and I would imagine a fresh install of course had no nesting... will my layout, as I now see it on the ipad, be wiped out as soon as I resync? I have backups, so is there a specific file I should be looking for?
    Attached Thumbnails Attached Thumbnails HELP - iTunes not showing apps; afraid now to sync to i[ad2-ipad_apps_device.png
    62587
    Jun 2011
    12
    Issue continued here and resolved .
  1. Replies: 3
    Last Post: 07-22-2011, 01:53 AM
  2. itunes won't sync all apps to ipad
    By wuphie77 in forum iPad Help
    Last Post: 05-02-2011, 02:48 PM
  3. Apps not showing up on itunes
    By walkerinwhistler in forum iPad Apps
    Last Post: 04-15-2011, 05:54 PM
  4. itunes sync problems (apps)
    By scoobyberry in forum iPad Help
    Last Post: 06-18-2010, 09:52 AM
  5. Replies: 1
    Last Post: 06-16-2010, 09:20 AM
apps not showing after sync
apps not showing in itunes
apps not showing up in itunes
ipad 2 not showing in itunes
ipad sync not showing apps
itunes not showing all my apps
itunes not showing apps
my apps not showing up in itunes
no apps on itunes
no apps show up in itunes
no apps showing up in itunes
why are my apps not showing up in itunes
