Missing Contacts
This is a discussion on Missing Contacts within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have an iPad2. About 4 months old. Got some info out of contact and then tried to search another. All of my contacts are ...
Results 1 to 2 of 2
    98095
    Sep 2011
    Canada
    Missing Contacts
    I have an iPad2. About 4 months old. Got some info out of contact and then tried to search another. All of my contacts are gone. How can I recover my contact database. I appreciate the "sync with Outlook" response but I have updated info on the iPad that is not in Outlook. I want to recover the database off of the iPad, not resync. Can anyone tell me how to do this and get my contacts back? Many thanks
    91324
    Aug 2011
    United states
    128
    Firstly,we should make sure the contacts are really gone..
    Try to hold the search option on the contacts,if there is anything in the field,it will affect where the contacts are belongs to...
    Then check the red ribbon on the right named group,tap it and see whether you can the right address book or not and/or select the group...The ribbon will not be there depends on how you set up your contacts.
    Thirdly,try to press and hold down the power button,when the shut off image appears, and then restart the ipad,waiting for the appear of apple logo.
    If your contacts are still in limbo, there is one other possibility.
    If you have not synced your iPad to iTunes since the contacts disappeared, they may still be in your last backup.
    Open iTunes (without the iPad connected) go to Preferences, and the Devices tab. You’ll see a list of backups, only one per device that you sync with iTunes. Check the dates.
    While you are there, turn off auto-sync. It will make it easier to manage when you iPad syncs in the future. It’s important now, because you don’t want the iPad to start syncing when you plug it in. The first thing it would do is overwrite your backup.
    If that looks good you can choose to restore your iPad data. You will lose everything stored in a app since the last time you backed up the iPad. So go through all your apps first and save the important files, photos, whatever to the computer, or email them to yourself.
    Connect your iPad.
    In iTunes, under the Device list, right click on your iPad and choose Restore from Backup. Be sure it says ‘from Backup’, not just Restore. Select the backup from the list and cross your fingers.
    Hopefully that worked. If not, and you don’t have your contacts backed up in some other program, you are stuck with entering them again manually.
    In the future I recommend syncing your Contacts with an online service like Google. It will be a lot easier to recover them if anything happens to your iPad.
    Hope it will work then,..
  1. Contacts deleted or missing
    By Capt in forum iPad Help
    Last Post: 08-19-2013, 01:37 AM
  2. Ipad2 gmail contacts missing
    By calafair in forum iPad Help
    Last Post: 07-05-2011, 07:58 AM
  3. Contacts missing
    By dante9a in forum iPad Help
    Last Post: 05-22-2011, 10:39 PM
  4. Replies: 8
    Last Post: 05-01-2011, 01:11 PM
  5. iPad "Mail, Contacts, Calendars" missing
    By sweetness2020 in forum iPad Hacking
    Last Post: 03-07-2011, 04:25 PM
contacts missing from ipad
contacts missing on ipad
contacts on ipad disappeared
ipad 2 contacts disappeared
ipad contacts missing
ipad losing contacts
ipad missing contacts
lost contacts on ipad
