Portrait/landscape mode not detecting?
This is a discussion on Portrait/landscape mode not detecting? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; My ipad2 won't switch when I rotate it. I made sure the lock switch was'nt locked already. Any other help with this? Thanks!...
Results 1 to 7 of 7
    96228
    Sep 2011
    Thanks!
    116 times
    15,249
    Check that you've not accidentally swithced the Mute switch function to a soft switch in the multi-task bar. Double tap the Home button to open the multi-task bar and then check the soft switch at the far left of the multi-task bar. It's interchangeable with the 'hard' switch near the volume control (you can set which one is which in the 'Settings' menu)
    96228
    Sep 2011
    Yes,we had noted that in another thread and the rotate
    Lock is off. This is my son's new month old iPad 2....
    38516
    18 times
    Seattle
    555
    I would first set everything back to default. Go into settings-general and then scroll down to the Use Side Switch to: and select Mute. Then I would do what Tim suggested, double press the home button twice to bring up the multi task bar, then swipe that bottom bar from left to right to bring up the video controls and make sure the volume icon on the far left does not have a slash through it and the volume level on the right is set at about 50%. Then press the home button to close the multi task bar. Make sure the slide button above the volume rocker is in the up position so that the device is not muted. Now I would do a reboot by holding down the home button and power button at the same time until the device powers itself off (about 5-7 seconds). Let it sit for about 20 seconds then power the iPad back on which take a little while. If that doesn't fix it then you can either try a restore or take it into Apple.
    iPad 2 64GB Wifi 5.1.1 jailbroken
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,257
    In addition to all this, some apps just don't rotate. They are built to be in portrait or landscape - and you can never rotate that app. For example, Words With Friends is always in portrait mode (with the home button down) no matter what you do or what the iPad settings are. It's just the way some developer's create their apps.
    Just to throw that thought into the mix...
    96228
    Sep 2011
    Will restarting my iPad delete all the apps and information I have collected?
    13576
    743 times
    Aug 2010
    9,257
    No.
    It's perfectly safe to do a re-start of the ipad (and a reboot, for that matter).
  1. Portrait or Landscape?
    By graywolf in forum Apple iPad Polls
    Last Post: 03-31-2013, 05:40 AM
  2. portrait or landscape?
    By ivanmarkchang in forum iPad General Discussions
    Last Post: 05-21-2011, 06:25 PM
  3. Display mode switch for Portrait/Landscape
    By leotb in forum iPad General Discussions
    Last Post: 12-17-2010, 12:56 AM
  4. Portrait or Landscape?
    By sbarnes8478 in forum iPad General Discussions
    Last Post: 07-02-2010, 09:50 PM
  5. My iPad has stopped detecting portrait and landscape.
    By Plawrence1956 in forum iPad FAQ
    Last Post: 06-13-2010, 05:40 PM
how to change from portrait to landscape on ipad2
ipad doesn't switch to landscape
ipad won't go into landscape mode
ipad wont rotate to landscape
missing portrait or landscape mode icon on ipad 3
why does my printing produce landscape not portrait from ipad
words with freinds please rotate to portrait
words with friends ipad rotate
words with friends landscape ipad
words with friends portrait mode
words with friends rotate
words with friends wont rotate on ipad
