iPad so slow.
This is a discussion on iPad so slow. within the iPad 2 Forum forums, part of the Apple iPad Discussions category; When I type a reply to mail, the words do not happen as I type. I can hear the key clicks but it takes a ...
Results 1 to 6 of 6
Thread: iPad so slow.
    82505
    Jul 2011
    20
    iPad so slow.
    When I type a reply to mail, the words do not happen as I type. I can hear the key clicks but it takes a few seconds for the text to appear. Although as I type this now it is normal.
    Also when I read my mail it takes a while for the text to load on screen.
    Is it possible that some where in the iPad something is filling up the memory and causing the slow down?
    78549
    8 times
    Jul 2011
    Oconto, WI, USA
    257
    If you power down you iPad and restart it any open programs should close thereby freeing up memory.
    Are you jailbroken? If so you can swipe the upper task bar and access processes to free memory.
    Cheers, Dan
    iPad 2 32gb wifi 6.1.2 jailbroken with Evasi0n
    iPhone 4s 16gb 6.1.2 jailbroken with Evasi0n
    iPod Touch 2nd gen 32gb wifi 4.2.1 jailbroken with Greenpois0n
    "To acquire the habit of reading is to construct for yourself a refuge
    from almost all the miseries of life." W. Somerset Maugham
    82505
    Jul 2011
    20
    Jail broken? Do I need to know of this, tell me more.
    38516
    18 times
    Seattle
    555
    No you do not need to be jailbroken, there is a tweak (SBSettings) that will allow you to kill running apps if you are jailbroken, I think that's why they were asking. Also, just press your home button 2 times quickly. This should bring up a row of icons along the bottom of the screen. Press and hold on one of them until they start to wiggle, then press the hypen symbol inside the red circle and this will kill the app. Once you have done this to all the apps, press the home button to get out of the edit mode and then press the home button again to get rid of that bottom row. Now power down your ipad, wait about 30 seconds and then power it back up. This should refresh your memory.
    iPad 2 64GB Wifi 5.1.1 jailbroken
    82505
    Jul 2011
    20
    I did as suggested and closed the apps on the bottom of the screen. I switched off and waited 10 seconds or so but I could not switch on. The iPad was dead or so I thought.
    I was going to attach to my PC but I first plugged in the charger and it came back to life.
    It had me worried for a while.
    It seems to have done the trick as the iPad now worked much faster.
    Thanks people for your help.
    38516
    18 times
    Seattle
    555
    when you power it back on it will usually take a little while, not to worry
  1. iPad 2 running very slow
    By Mikey180000 in forum iPad Help
    Last Post: 03-02-2012, 05:46 AM
  2. Would too many tweaks slow your iPAD
    By peled in forum iPad Hacking
    Last Post: 02-12-2012, 04:13 PM
  3. iPad slow
    By nana49er in forum iPad Help
    Last Post: 08-18-2011, 06:46 PM
  4. my iPad has gone slow please help!
    By Burley89 in forum iPad Help
    Last Post: 07-16-2011, 01:49 AM
  5. iPad Safari - Really slow
    By DaveSmith in forum iPad Help
    Last Post: 10-12-2010, 08:19 AM
ipad 2 64gb slow
ipad 32gb running slow
ipad slow to type
ipad typing very slow
slow
why does my ipad type slow
why ipad so slow
why is ipad so slow
why is my ipad 1 so slow
why is my ipad so slow
why is my ipad so slow typing
why is my ipad typing so slow
