Problem Zino closing down
This is a discussion on Problem Zino closing down within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi I have got a problem with my Zino apps closing down. It has been working for 2 month without problem, but now when I ...
Results 1 to 2 of 2
    91996
    Aug 2011
    Thumbs down Problem Zino closing down
    It has been working for 2 month without problem, but now when I start it it starts up in Explore mode and when I try to start Read mode it just close down.
    Any tips what to do?
    /Niki
    119 times
    15,248
  1. Zino?
    By Steve_bham in forum iPad Apps
    Last Post: 07-07-2011, 01:27 PM
  2. Closing an app
    By Joeleo1937 in forum iPad Apps
    Last Post: 07-01-2011, 03:01 PM
  3. App's closing....
    By Jlocro in forum iPad General Discussions
    Last Post: 04-01-2011, 03:00 PM
  4. Closing mailbox?
    By iPed in forum iPad Help
    Last Post: 09-09-2010, 07:57 AM
why does zino close down on ipad
why does zino keep closing
why does zino keep crashing
zino keeps crashing on my i pad
zino problem
zino problems on ipad
Tags for this Thread
