Xilisoft iPad Magic
This is a discussion on Xilisoft iPad Magic within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello everybody, I do not like iTunes and got Xilisoft iPad Magic to install and manage music, books and stuff on my iPad! Everything worked ...
Results 1 to 2 of 2
    91537
    Aug 2011
    Xilisoft iPad Magic
    Hello everybody,
    I do not like iTunes and got Xilisoft iPad Magic to install and manage music, books and stuff on my iPad! Everything worked great until today!
    I started iTunes to check something and got the usual update window which I canceled. But when I went back to the Xilisoft software none of my music files or my ebooks showed up anymore! Xilisoft shows the stored bytes as other stuff but no individual files anymore!
    Any idea what happend? and of course how to get the full functionality of Xilisoft Ipad Magic back???
    Thanks a lot for your comments and ideas!
    91537
    Aug 2011
    ok here's an update! :-)
    After testing all kind of things I found that iTunes too could not read my iPad anymore! That got me to thinking! I searched the internet and found that others have similar problems. I read that one guy tried to delete some itnernal files and afterward everything worked again. Somebody else suggested to use MediaMonkey. Since I did not want to go inside the operating system I tried MediaMonkey. I downloaded a free trial version and tested my iPad. There too the iPad showed with memory being taken by "unknown" stuff and neither books not music showing anything. I then saved a new song to my iPad with MediaMonkey and that showed up. I then used iTunes again and iTunes could read my iPad again. After a new sync everything is back to normal!
    Right now I think maybe I caused the whole problem by using Xilisoft iPad Magic???? And frankly I do not know if I can or should use that software again! It is just so conveniant and nice to use - much like I expect the iPad should be handled. Almost the same like a laptop! I think that it really is very bad that Apple restriced the use of the iPhone and iPad to their iTunes software! This is not how I like it!
    OK problem solved! :-)
    Thanks for reading!!! :-)
  1. Xilisoft iPad Video Converter 6
    By pointdexler in forum Off-Topic
    Last Post: 06-16-2010, 07:15 AM
can not get my ipad to work with xilisoft idevice magic platinum pc
idevice magic
idevice magic platinum problems
idevice magic platinum. forum
ipad air is not detecting in xilisoft
problem registering idevice magic platinum
xilisoft ipad magic forum
xilisoft ipad magic not recognizing ipad
