Wi fi won't turn on
This is a discussion on Wi fi won't turn on within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi everyone, I'm a new iPad user and I was hoping someone could tell me why my wi fi turned off by itself and now ...
Results 1 to 10 of 18
    89976
    Aug 2011
    Wi fi won't turn on
    Hi everyone, I'm a new iPad user and I was hoping someone could tell me why my wi fi turned off by itself and now will not reconnect or turn back on. I've tried to turn it on manually and still no luck.
    Is this common?
    85789
    15 times
    Aug 2011
    Uk
    181
    The very same thing has happened to me this evening, about the time you posted. I left it for a wee while but it didn't reconnect, but the problem was solved by turning the iPad off (not just to sleep - hold the button down till the power off slider appears), then restarting. I was connected when I turned the iPad back on.
    I've had it happen once or twice before, but not often.
    90095
    Aug 2011
    My ipad wifi signals weak sometimes.
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    Yes, I've seen the wifi radio stick off before, and as Jockscrap mentioned, a reboot of the iPad normally sorts it out quickly. Most likely it just means the process has hung or crashed. Nothing to worry about. The iPad is generally very stable with IOS, but sometimes an app or process will have a funny moment, just like any other device.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    89976
    Aug 2011
    I'd be very disappointed if my iPhone 4 ends up being more reliable than my iPad 2. Even though rebooting is a quick fix, I expect a lot more than what I'm seeing so far. I hope I don't regret purchasing this iPad instead of waiting for the 3rd edition.
    85789
    15 times
    Aug 2011
    Uk
    181
    I've had it happen to me maybe twice or three times since I got my iPad at the end of May. I really don't think you need to worry. I was given mine as a birthday pressie from my lovely DH. I hadn't asked for one, desired one or thought i'd use one, but fortunately my DH knows me better than I do! Since getting my ipad, it never leaves my side, I use it constantly for everything and I couldn't imagine life without it now. Enjoy!
    88198
    Aug 2011
    Earth
    16
    HAppens the same to me When my ipad 2 is in standby than I wake it up the Wifi is connected but with no internet.
    I need to turn wifi off and then on again. this is very annoying I read is something abouth the firmware.
    I did a test I turn off the Wpa in the router and change to No Security and it seems fix the problem. Looks like is some conflict with authetifications.
    try to do that and let me know...
    88198
    Aug 2011
    Earth
    16
    ok I tested it put it to sleep and wake it up several times and now I dont have any problem with wifi conectivity. I had to change it to No authetification so now my router has no password at all and to have some save I hide the SSID
    I think for now is the solution
    iPad Guru
    49414
    467 times
    North Carolina
    3,128
    Quote Originally Posted by adz_1 View Post
    Adz - good luck w/ your Wi-Fi issue, hopefully just an infrequent fluke - rebooting the iPad is often a good first step w/ 'stuck' or 'frozen' apps - you can also 'close' an individual app by double-tapping the home button, holding the 'offending' app until the jiggling starts and closing the app -
    Also, from the statement above, I don't believe that you've lived long enough w/ the iPad to yet regret your choice - every day will likely bring you a better understanding of the device and the numerous and widely variable uses of it - enjoy!
    90266
    Aug 2011
    LTU
    I had same problem.
    I solved it by turning off and than turn on again. Try to do same.
    If you get this error again and again - try renew system or go to service.
  1. Cant turn of i pad
    By big dog in forum iPad Carriers
    Last Post: 07-09-2011, 01:54 AM
  2. Help, pad will not turn on
    By NightHawk in forum iPad Help
    Last Post: 05-22-2011, 08:51 PM
  3. i-pad won't turn on
    By camdxr in forum iPad Help
    Last Post: 04-26-2011, 01:26 PM
  4. Can't turn Ipad on
    By cyprus203 in forum iPad General Discussions
    Last Post: 03-07-2011, 09:46 AM
  5. Replies: 7
    Last Post: 06-03-2010, 03:34 AM
ipad wifi will not turn on
ipad wifi won't turn on
ipad wifi wont turn on
ipad won't turn on wi fi
ipad wont let me turn on wifi
my ipad wifi will not turn on
wifi won't turn on ipad
wifi wont turn on ipad
