Reboot does not close apps?
This is a discussion on Reboot does not close apps? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I "rebooted" my iPad this morning because last evening I sent emails and it doesn't seem like any of them went through, they weren't in ...
Results 1 to 10 of 17
    56427
    5 times
    May 2011
    265
    I "rebooted" my iPad this morning because last evening I sent emails and it doesn't seem like any of them went through, they weren't in drafts and they weren't in send, just gone. So I rebooted and it took a while with the swirly thing. Finally I restarted it and all the apps were still open when I double clicked the home button. Shouldn't a reboot close out everything and start fresh?
    116 times
    15,249
    No - a reboot doesn't close the apps. It's because many of those apps are not really running, even though they appear in the multi-task bar. iOS removes most of them from RAM (system memory) and only a very few of the app's functions are left running - playing audio for example. The remaining apps that 'appear' to be running simply have their state ('context') stored so that the app can be reloaded in exactly the same state as when it was suspended. Those context files are not cleared by a reboot, so the apps still appear in the multi-task bar. The only way to delete the context file - and hence remove its app from the multi-task bar is to manually close the app by pressing an icon in the multi-task bar until they all start to jiggle and then pressing the upper left hand corner of the app's icon. That tells iOS to delete the app's context file and so it no longer appears in the multi-task bar......
    29345
    50 times
    Penarth, Wales, UK
    1,936
    Look, he posted twice! Wot a nube
    116 times
    15,249
    Damn - it's that 'Post Quick Reply' on a marginal 3G link in the ASDA car park...
    29345
    50 times
    Penarth, Wales, UK
    1,936
    Yes, of course
    56427
    5 times
    May 2011
    265
    Thanks Super Tim!
    27208
    4 times
    Dec 2010
    50
    Interesting read! However what suprises me is that whenever I have apps minimized and they still appear in the multitask-bar, they seem to still eat-up ( a lot of) RAM. I check with System Status app. The Memory Tab shows Free memory and when I decide to close the apps from the multitask-bar, then a lot of memory is free'd up...in other words more Free memory in System Status. For example whenever I have iCab open it will have some 40-50 Mb of mem in use. When I close iCab, then those 40-50 Mb are free'd up.
    Maybe I'm missing something here, and you are able to educate me some more on this Thanks again.
    116 times
    15,249
    The iPad's operating system, iOS, manages the RAM. If a new app needs to be loaded, and there's sufficient remaining free space in the RAM, then existing apps are left there untouched. This means they can be re-activated quickly. If, when iOS, tries to load a new app, there is insufficient space in the RAM, then iOS will unload an app to free up space for the new app to be loaded into.
    Hence, in your example, if iCab is in the multi-task bar, it may well still be present in RAM as long as you've not had to load an app that would cause iOS to unload iCab. So, when you manually quit iCab, the RAM that it was occupying is freed up and you see the result of that.
    But if you'd not used iCab for a while and have loaded several apps since you last used iCab then, chances are iOS will have unloaded iCab. Now, if you manually quit iCab it's already been removed from RAM by iOS and your 'quitting it' is only deleting iCab's context file. So, now, you'll see next-to-no RAM being recovered.
    27208
    4 times
    Dec 2010
    50
    Very clear explanation, thanks very much. I know understand completely how memory management works on the ipad. Good to know that I can just leave things be and not manually close apps from the multitask bar everytime to free up ram. Totally unnecessary it seems.
    116 times
    15,249
    I see no reason really. Of course, some functions - such as playing audio - are left active. You can see the list of iOS tasks that remain active when an app is suspended on the Apple iOS Development website. I never bother unless an app starts to 'misbehave', then closing it can 'clean things up' and gives you a 'fresh start'.
  1. How do you close your apps?
    Last Post: 09-19-2012, 04:44 PM
  2. Dose apps auto-close when we shut it?
    By Thanhdao in forum iPad Apps
    Last Post: 07-09-2011, 09:46 AM
  3. Can't close apps
    By felixapproach in forum iPad Help
    Last Post: 07-09-2011, 02:45 AM
  4. How to close apps running in the Background
    By Al Rogers in forum iPad General Discussions
    Last Post: 02-19-2011, 10:55 PM
apps dont close in ios after reboot
apps still open after restart
does a reboot close all programs
does restarting iphone close all apps?
ipad reboot not closing apps
iphone applications still open after reboot
iphone apps still running after reboot
iphone apps still running after restart
iphone apps stoll open after reboot
iphone opens apps on reboot
iphone restart doesn't kill app
reboot ipad apps still running
