Reboot does not close apps?
This is a discussion on Reboot does not close apps? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Why I kept closing apps manually is because it seems like the ipad is slowing down a bit whenever much is visible in the multitask ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    27208
    4 times
    Dec 2010
    50
    Why I kept closing apps manually is because it seems like the ipad is slowing down a bit whenever much is visible in the multitask bar. I could be mistaken of course, however it does seem like it. When the apps are "closed" then the system becomes a bit snappier.
  3. #12
    116 times
    15,249
    For sure - if you've unloaded an app and freed up some RAM then, when you start another app off either (a) it's still in RAM because you unloaded other apps that were in RAM and so iOS could leave this particular app in RAM, so it starts faster because it doesn't need to be reloaded or (b) you've freed up RAM by unloading apps so, when you come to load another app, iOS doesn't need to unload an app that's already in RAM as you've already done this for iOS.
    So your observations make perfect sense!!
  4. #13
    27208
    4 times
    Dec 2010
    50
    Ah that does indeed make perfect sense! The logic behind it is definately there. I therefore assume apps that are still in RAM won't use any battery either, correct? Thanks again for all your help.
  5. #14
    116 times
    15,249
    Generally speaking, you're right, though iOS does allow an app to keep some functionality active when it's suspended - I mentioned audio before, for example. So there is at least the opportunity for a suspended app to use some battery.
    If you're interested in looking at multi-tasking in some more detail, there's an interesting presentation here....
    http://labs.tranquilli.org/docs/iOS4...tranquilli.pdf
  6. #15
    27208
    4 times
    Dec 2010
    50
    Tim...thanks! I will check out the document as well...
    Edit : have read the document, but although I understand some parts, most of it is too technical for me personally. I understood your info much better
  7. #16
    23848
    Dec 2010
    Mich.
    102
    Apple should have included a icon you click that closes all open apps or made the operating system clear all apps before it shuts down as most OP's do.
  8. #17
    41271
    48
    This is my biggest complaint that I have with the iPad. Its extremely annoying how much hassle it is to close down programs.
  1. How do you close your apps?
    Last Post: 09-19-2012, 04:44 PM
  2. Dose apps auto-close when we shut it?
    By Thanhdao in forum iPad Apps
    Last Post: 07-09-2011, 09:46 AM
  3. Can't close apps
    By felixapproach in forum iPad Help
    Last Post: 07-09-2011, 02:45 AM
  4. How to close apps running in the Background
    By Al Rogers in forum iPad General Discussions
    Last Post: 02-19-2011, 10:55 PM
apps dont close in ios after reboot
are apps still running on the iphone if not cleared out
does restarting iphone close all apps?
iphone applications still open after reboot
iphone apps still open after reboot
iphone apps still running after reboot
iphone apps still running after restart
iphone apps stoll open after reboot
iphone restart doesn't kill app
reboot ipad 3 still not close applications
reboot ipad apps still running
reboot ipad but apps still running
