Please help..newbie ipad 2 owner
This is a discussion on Please help..newbie ipad 2 owner within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi, just got a new ipad 2, (welcome to the world of apple), anyway, can somebody please guide me as to what do I need ...
Results 1 to 6 of 6
    87411
    Aug 2011
    qatar
    Hi, just got a new ipad 2, (welcome to the world of apple), anyway, can somebody please guide me as to what do I need to do to convert my wired internet connection in my room so that the ipad 2 can connect to it? I was just being overwhelmed by the bunch of informations I need to understand about this device.... thank you and looking forward for some inputs...........thanks.
    116 times
    15,249
    If you have a wired Internet connection then all you need is a wireless router. Another - and cheaper - alternative, if you have a PC, is to purchase a USB WiFi 'dongle' for your PC and then turn your PC into a WiFi hotspot.
    The wireless router is the technically easiest route forward - almost any wireless router will work - for example the Apple Airport Express - but it's the most expensive. A USB WiFi dongle can be purchase for just a few dollars, but then there's some configuration to be done on the PC to make the PC into a WiFi hotspot. We'd be happy to guide you through either approach.
    29345
    49 times
    Penarth, Wales, UK
    1,934
    welcome to your new ipad!
    yes, as Tim says, you need to wirelessly transfer your internet signal to your ipad - a router does this. buy a cheapy one. only a couple of bucks. dont be collared into buying expensive. just not needed. i use a third hand linksys jobbie offof ebay. cost me about 10 bucks including postage. works a dream and is nice and fast.
    and dont worry about learning a bunch of new apple stuff - believe me, it's super super fast and easy to pick up. thats the beauty with apple's stuff - the thinking is kept to a minimum. they do all that for you. use your device and you'll be fluent within an hour i assure you!
    87411
    Aug 2011
    qatar
    thank you guys for the heads-up..... i think i have to go to the wifi router route....... i will try to get one and let you know guys, so just to clarify,any wifi router will do? any specific brand out there that stands out from the others, yes, i understand the airport express is really expensice............nice to know i can use ordinary wifi routers.....
    29345
    49 times
    Penarth, Wales, UK
    1,934
    something like this will do (just an example) -
    Linksys WRT54G Wireless Router version 5 | eBay
    87234
    Aug 2011
    Philadelphia
    14
    Routers
    Quote Originally Posted by ipadqatar View Post
    Yes, and you don't need to order it online - just go into your local Best Buy or similar store. Linksys, D-Link, Netgear are all reasonable brands and, as noted, the Apple one is more expensive, and not better. - and you don't need a super-fast one, since IPADS only support standard speeds for WiFi.
    J
  1. New iPad 2 owner
    By Bimjo in forum New Member Introductions - Site Assistance
    Last Post: 06-06-2011, 07:53 PM
  2. Hello new ipad owner
    By poncer55 in forum iPad Help
    Last Post: 06-05-2011, 08:11 PM
  3. New ipad owner
    By Martlet in forum iPad 2 Forum
    Last Post: 03-23-2011, 01:32 PM
  4. Ipad newbie...newbie problems
    By piper109 in forum New Member Introductions - Site Assistance
    Last Post: 12-19-2010, 10:58 AM
  5. New UK IPad Owner
    By jthspace in forum New Member Introductions - Site Assistance
    Last Post: 06-28-2010, 05:21 PM
belkin f5d8055
